Double checking my tire needs on BX24
   / Double checking my tire needs on BX24 #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
My property is on the water. Lot's of sand. Some rough grass (which can be soft). And a "Crushed Bank (mix of sand gravel and clay I think)" steep road I wish to maintain with it.
I plan to move lots of rocks. Some on the edge of the water in sand.
I might try to use it to launch my boat.
I may distribute sand and sod with it.
I may use it in the winter on occasion if the plow doesn't show up or makes a mess or I need to access an area not normally plowed. No plans for a snow blower at this time.
I plan to dig out a bunch of stumps.
I may add a box grader or scraper for grooming the road.
No mowing.
I'm thinking turf tires. Not so much to protect the little bit of grass but a lot of land is loose on my property (the sand and the crushed bank road). And I think aggresive tires will tend to dig in rather than try to ride on top.
What do you think?
   / Double checking my tire needs on BX24 #5
   / Double checking my tire needs on BX24 #6
Ken_CT said:
Here is a post from an earlier thread that has an excellent explanation of tire types & uses.
Good info.:D
   / Double checking my tire needs on BX24 #7
Ken_CT said:
Here is ... excellent explanation of tire types & uses.
Thanks mate!
   / Double checking my tire needs on BX24 #8
R4s are the safe bet (i.e prevents you from making an "all-out" mistake). But they might not optimize your potential (like Ags would), particularly in hauling rocks up slopes, towing, etc. From what you describe, Turfs would leave you wanting for more grab.
   / Double checking my tire needs on BX24 #9
That is what I was thinking.;)
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
