don't run right
/ don't run right #1
snopro440
kalkaska,mich
jd 110
don\'t run right
i have a older jd and it will start right up,but give it a minute to warm up and it starts running bad until it just stall's ,about 4-5 minutes-does anyone have any ideas? it ia a older 110 with a 8hp kohler
/ don't run right #4
Re: don\'t run right
I would give the same advice as RaT but add that a dirty carburator or fuel can do some strange things.
Just a couple of more questions though.
Will it start right back up or do you have to wait a while?
Did it run OK last season.
You need to give us more info. All you can think of and more.
/ don't run right #5
Sounds like it could be in the fuel system, like it was said before, check the gas cap, fuel filter and carb for obstruction, sometimes the needle valve will stick if its dirty. If all this fails, try a tune up with a new condenser. A bad condenser will drive you crazy.
/ don't run right
yes billyp, i have to let it set for a bit before it will start again.i have removed the fuel cell and cleaned it,and also the carb.i have also replaced the plug and coil wire,and still the same thing.
i am starting to get frustriated with it any help will would be great.
/ don't run right
thanks garyp,everything you can tell me helps
/ don't run right #8
Try running it and then loosen the gas cap just about the time it cuts out. If no air gets into the tank, it will starve the engine of gas even if the engine has a fuel pump.
/ don't run right
thank's RAT,i took your advice and did it and it still does the same thing. it act's like it's leaning out to-much as it's stalling out,it back fire's and blow's flames out the exhaust.
/ don't run right #10
Good chance then you need to pull the bowl and check the float. I have a similar engine and that is where the problem was. Water corroded the bowl area and the float/needle valve were messed up.
/ don't run right #11
Check the points, oil could be coming past the plunger and getting on the contacts, this will typically happen within the first five or ten minutes, after it quits and sits for a bit the oil will runn off the contacts and it wiil start again. Next time it quits check for spark...
/ don't run right #12
If your spark checks o.k., you could have an exhaust valve sticking. Some air cooled engines can experience this when there is excess carbon build up on the valve stems. The only cure for this is to remove the cylinder head , remove the valves and clean them up and also clean the valve guides.
/ don't run right
thank's guy's for your help, i'll pull the head this afternoon and see what's up.
/ don't run right #14
Beet me too it. Kohlers have been known for the exhaust valve sticking. Sometimes you can just clean it up and be good to go.
Good Luck
/ don't run right #15
I believe somebody mentioned the condenser, the symptoms you describe can be attributed to a bad condenser. A coil can break down similiar to that also. After engine quits can you attach an extra spark plug and check for fire?
3015 (A56857)
3015 (A56857)
2009 Volkswagon Jetta Sedan (A61574)
2009 Volkswagon...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2025 Kivel 48in Fork and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
