Done built me a spray rig!!!!
/ Done built me a spray rig!!!! #1
bartman
Adamsville Pa / Williamsport Md
John Deere 2640 / Ford 1710 / MTD 2554 ZERO TURN MOWER
I have 15 gallon 12 volt hand spray rig which I bought at a local TSC/ Cenral tractor place.It worked good for spraying around the house/bnarn etc. When I tried to spray /burn-off a few 1-2 acre fields it was a disaster.
Thus I went out and bought 6 spray tips, 3/8 AG tubing and 10 foot of Schedule 80 gray PVC pipe. Rigged her up and was able to turn the road in front of the house a wet color. It covered approximately a 10 foot path and I calculated that I can do almost 1 to 1 1/2 acres just using a 15 gallon tank.
I will be taking the "RIG" up to the farm this weekend and try it out with some round-up . Hope the weather didn't get too cold for the round-up to work
Sorry no pictures.Mama took the camera to Florida
Bartman
/ Done built me a spray rig!!!! #2
Pictures, please pictures are worth a thousand words. Does sound like a neat rig thou.
/ Done built me a spray rig!!!! #3
Maybe TBN can sponsor a discounted special on inexpensive digital cameras that take pictures less than 100K. Such a camera would be pretty inexpensive. Then everyone when the register can be encourage to buy one and share their experiences in digital video.
/ Done built me a spray rig!!!! #4
There are digital cameras available at Wally World for under $20. Of course they use bmp format, so you'd need an editor to convert the pics.
/ Done built me a spray rig!!!! #5
There is an inexpensive polaroid for about 30 bucks from wallmart.. and it saves in jpg format... has a low res option I believe.
There are also some oher ones there.. and a couiple at kmart.. small ones.. like 20-30 bucks.. One is about the size of a computer mouse.. holds about 10 pics.. low res.. etc.. plugs into serial port.. etc.
Soundguy
Mama's back from Florida and brought the camera back in one piece. Only problem is Me /mama /camera are in Maryland and the spray rig is back up at farm in Pa. Should be heading back up there next week-end to start winterizing everything and hopefully I can take some pictures of the spray rig
BTW it worked excellent , it sprayed out all 15 gallons of round up. The last 2or 3 gallons foamed up a lot and the pump stutters when it starts suckin foam,but she worked great
Hopefully we will see that the grass in the pasture is starting to burn-down by the time we make it back up there
Bartman
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
