DOM tubing question
   / DOM tubing question #21
Last time I tried acting like a mechanic under a shade tree the silly thing dropped a branch on the hood. Then I had to act like a shade tree body man.
   / DOM tubing question #22
seems to me the bushing and pins dont move relitive to each other, only the cylinder bushing rotates
so you dont need clearence for greese, measure the cylinder bushing diameter and work from that
if im right i would just put a bolt through the weldiments and a spacer for the cylinder and weld them in place, weld a lil at a time to control heat and alternate sides when welding
a class 5 or 8 bolt should be a few thausanths under and can be polished a lil more under where the cylinder bushing is
even if you have to drive the bolts into the welded bushings it shouldnt matter, only the cylinder bushing clearance matters
when you use the spacer make sure its atleast .010" longer than the cylinder bushing for grease to seep out the ends for lube
2001 Freightliner MB55 Chassis Bus (A56858)
2001 Freightliner...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
