Dollar General lubricant
/ Dollar General lubricant #1
sherpa
Platinum Member
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
Anyone ever use DG (Dollar General) spray lubricant on their tractors? I wanted to let you know how well this stuff works. I use it all the time on my 3 point hookups. This stuff is better than grease and no where as nasty. I spray this stuff on every one of my implements and it stays on there a long time and it does not get cold and hard like grease. I use it on my top links and they stay nice and free and easy to adjust. I bet someone else has already found out how good this stuff works. I don't know how the first can got into my lubricants but I saw it one day when I needed to lubricate something. After that I use it all the time now.
sherpa
/ Dollar General lubricant #2
I use 00 grease for that and it works well. As you say, there's very little mess.
/ Dollar General lubricant #3
I use the same grease for everything on the tractor and implements. It's a standard Lithium based grease( nlgi-2). Watch what you're doing and wipe when done - works OK for me.
/ Dollar General lubricant #4
sherpa
I will check that out, can’t believe I haven’t seen that yet!
***Thank you for your sacrifice, sherpa***
/ Dollar General lubricant #5
Are you referring to their store brand WD40 counterpart? Seems to work as well as the real thing, but I've never used it in places meant to be greased.
It's amazing how nice and easy all the tractor pins move in out after you sprayed them with DG Lubricant.
/ Dollar General lubricant #7
Sounds like WD40 Specialist, goes on like foam and gets into everything, sticky and doesn't dry out or wash off in rain
/ Dollar General lubricant #8
I was in one of there stores for the first time about a month ago, I know I live a sheltered life LOL.
I could not believe all the items they carried, I guess I have something else to check out now.
/ Dollar General lubricant #9
They've really been expanding over the last few years. 5 years ago I'd never even seen one, now there are probably a half dozen within a 25 mile radius.
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
