Does your fuel gauge actually work?
/ Does your fuel gauge actually work? #23
Fuel gauge is fine on mine. Yes, it stays at F or above for the first couple gallons, then it drops quick. Not an issue, when I am at 1/2 tank or a little less it takes 5 gallons. When it's all the way down to E it takes 7-8. I prefer that to sputter sputter shake stop.
/ Does your fuel gauge actually work? #24
Fuel gauge yes, temp not so much.
The way to get the temp gauge to move off 1/4 is to bush hog or mow really thick and wet grass for long periods. It helps if the grille in front is partly packed with grass clippings. It's the only way I ever got the gauge to move.
/ Does your fuel gauge actually work? #25
L2800 gauage doesn't show the correct level of fuel in tank,thats okay because I diesel up most everytime before use...learn that from Farmall H many years ago. ;)
/ Does your fuel gauge actually work? #26
My BX24 gauge stopped working and I traced it to a ground at the left rear. Worked fine since but it does fluctuate a little on rougher ground. Lets me know whenI need to come in and fill OK.
/ Does your fuel gauge actually work? #27
i just replaced my temperature gauge Saturday now they all work.
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2007 MACK CV713 DAYCAB BOBTAIL VAC TRUCK (A65643)
2007 MACK CV713...
(1) Small Livestock Feeder Gate (A66408)
(1) Small...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A64553)
2023 Caterpillar...
