Does widening front end stress axle/bearings more?
   / Does widening front end stress axle/bearings more? #21
Attached is a diagram from a manufacturer's operating manual showing the front wheels in their respective "dished-in" and "dished-out" positions. I'm not for sure what it does for bearing wear (I can understand the OP's argument though that the magnitude of the torque shouldn't be more just whether it is positive or negative) but I know the tractor steering wheel is much more difficult to turn when the front wheels are at their wider position.
   / Does widening front end stress axle/bearings more? #22
Yes, but when you reverse (or swap) the tires to make a wider stance the distance between the center lines hasn't changed, it just the center line of the tire has moved from one side of the bearing's center line to the other. The offest distance is the same in both cases. Same distance = same torque on bearings.
The center line of the tire has move from one side of the HUB FACE to the other. The offset distance is the same FROM THE HUB FACE. Are the bearings in line with the hub face?
xtn
   / Does widening front end stress axle/bearings more? #23
If the rim is centered on the wheel, and the wheel is centered in the tire, and the tire is symmetrical, then reversing the rims will not increase the width of the tractor or the the axle. In such a case, reversing the rims doesn't do anything for or against you unless you want to evenly wear the back side of the treads. I've never run into a need to rotate the tires on a tractor, but then I'm not habitually spinning my rear tires and grinding them down.
If the rims are not centered on the wheels, then swapping them around will decrease or increase your width (depending on which way you change them). This will also decrease or increase the moment arm, and consequently, the forces on your axle and bearings. On a CUT, I'm assuming that's going to be roughly 6 inches per side. Obviously on the big farm rigs, that may be a foot or more depending on the size of the tires and rims.
Good discussion. But no consensus. :cool: Reminds of that old Dire Straits song lyric: "Two men say they're Jesus, one of them must be wrong!" :confused2:
   / Does widening front end stress axle/bearings more? #25
concensus:
Yes Widening the front end stresses bearings more.
Consider to decrease the load by a corresponding amount, and perhaps decrease the travelling speed when carrying large loads.
If you make changes, small changes are better than big changes.
You might ask yourself if this stance change actually increases productivity.
howzzat for a concensus? (actually its just my opinion…..:thumbsup:)
   / Does widening front end stress axle/bearings more? #26
I would say regardless of the wheel bearing debate, having the wheels wider will definitely put more stress on the pivot bearings of the steering knuckles, and the axle beam itself.
If you want to get technical it is impossible to make a rim that is centered on the bolt face in both directions because the rim has thickness. I guess you could compensate for this if the hub flange was offset by exactly half the thickness of the rim. I understand this isn't the question, but someone brought up a point sort of implying this.
   / Does widening front end stress axle/bearings more? #27
...but if the rim is centered on the hub because of the dish, it's going to be centered when you turn it around (or swap it) around, and you haven't changed the width . That's the point, I'm trying to make, it's offset when in narrow, and it's offset just as much when its turned around = same amount of torque on bearing.
That is: When it's dish in (narrow) the torque wants to fold the bottom of the tires in. When you swap the "dish" and widen, the torque wants to collapse the bottom of the tires out. Your offset is the same in both cases, just on a different side of the vertical axis of the bearing, and thus the torque is the same on the bearing, just in a different direction.
If the rim is centered on the wheel hub in both positions, then... you haven't widened the stance!
   / Does widening front end stress axle/bearings more? #28
Here is my (possibly poor) attempt to put some sort of math to the problem. My better judgement says not to do this, but "'tis the season for sharing", right? The moment (torque) M is calculated in each scenario. The "hub" is considered fixed in position by the bearing arrangement, whatever that is, as long as it's the same in both cases (which is sure ought to be!) The moments magnitudes will calculate out differently by the difference in the thickness of the rim at the point of contact with the hub. This may or may not be significant depending on the ratio of the thickness of the rim to the offset of the "dish". In other words, if the dish is offset by 1" (from the centerline of the tire where the force is assumed to be acting from the weight of the machine) and the wheel thickness is 0.25", then the moment will be different by about 25%. If the dish is 3" offset from the centerline, then it would only affect the moment by about 0.25/3 = 8%. Not really the results I had in mind, but this is what my diagram indicates. Certainly mark it up or propose alternate diagrams so we all can learn what's really happening in this wonderful endeavor. The subject comes up enough to deserve a correct answer while we wait around for the next tractor job :)
   / Does widening front end stress axle/bearings more? #29
Coby got in on this type of discussion on another thread here on TBN. I posted some pictures on that thread to show the OP that he was adding stress to his front axle. I'll help Coby out and post them here.
Also, let me comment on Gary Fowler's statement about the front wheel being the same distance inside the bearing cupped in as it as outside the bearing cupped out. That's not true. The center of bearings are inside the hub flange. You can never get the wheel as far inside the bearing center as you can outside. With the wheel set clear in, it's still running outside the bearing center.
Okay guys, which tractor is exerting the most force on the axle bearing assembly and why?????
   / Does widening front end stress axle/bearings more? #30
After thinking this over some more I've concluded my analysis in my previous post is wrong for the purposes of this thread. The question revolves around the stresses on the bearings and the analysis does not address that question. Therefore, it should be adjusted to consider each bearing position on the final drive shaft in relation to the force applied to the center of the tire (if we assume the force is indeed centered on the tire). I'm thinking this would then lead to a conclusion that moving the tires out would indeed increase the stresses seen in the bearings.
RHINO SE8A SHREDDER (A52472)
RHINO SE8A...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53472)
2017 KINZE...
2009 UTILITY TRAILER MFG. CO. SEMI TRAILER 57 (A52472)
2009 UTILITY...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
