Does this look like it has float?
/ Does this look like it has float? #1
brokuly
Ford 4100
I want to believe that my loader will float. But I don't know anything about hydraulics. This is on my Ford 4100, just some random old triple valve on top of the tranny. Loader is hooked in through the rear remotes. No names or numbers on it, and no one around here has seen one like it.
Today I took it apart. That valve is the one that goes to the loader. The other two valves will spring back to center -- this valve that I took apart will stick on either end of the throw. Which is why I was thinking maybe it should be able to float... otherwise I thought maybe there was some crud in it gumming it up, but it's clean and tight inside. No slop in the spool at all.
I feel like the two small ports on the valve would let oil bypass, but like I said I'm just guessing.
I was also thinking -- previous owner had added quick connects underneath to make it easier to remove loader. Could tee-ing in like this screw up the circuit?
/ Does this look like it has float? #3
Can't help on float or not. Being a remote valve it's probably just detents to keep circuit live for running something with continuous flow requirement.....like a logsplitter that has it's own valve.
Regarding the tee'ing....hard to say if that's an issue without knowing where all 3 hoses go.
In general...on an open center system, the only tees are for tank lines OR for controlling more than one cylinder at the same time. For example....loader cylinders are teed together so they both raise and lower the same
/ Does this look like it has float? #4
Float would be on the loader valve that raises the arms.
Does it have a mechanical trip to dump the bucket or another valve to curl the bucket?
There's a valve for the loader, a valve for curl, and an extra remote on the rear.
/ Does this look like it has float? #6
Shove the loader valve hard forward past the detent, it will stay there in float.
When I was doing that it would just keep putting down pressure and pick the front end off the ground
/ Does this look like it has float? #8
I push the loader valve past detent and then let go of the lever. My bucket is now in float. If I keep the valve all the way forward - by pushing/holding it there - it will raise my front end off the ground.
/ Does this look like it has float? #9
Looking at the picture of the spool, I would say it does not have float and not much controllability either. Float spools normally will have a fourth land and I only see three in the picture. There are also no metering notches in that spool so it is essentially on/off. I would hate to try to set something in the bed of a pickup with that loader. :)
Thank you. That's what I was figuring. Time to buy a new remote kit. Having a bucket with no float is almost useless. Bummer.
Well I gave up hope on these old valves. Hoses need to be replaced anyways. Going to make this right.
Last night I ordered a hydraulic lid blocking plate, the tisco hv5902 hydraulic plate with power beyond port, and a chief p40 monoblock triple spool valve and the adapter to tap into the power beyond on the valve. One valve has float detent, and the other two are spring center. Local shop can make all the hydraulic hoses I need.
Got a good surprise as well, Bailey is celebrating their 50th anniversary and give up to 40 percent off an item so I ended up only paying 200 bucks for the valve plus shipping. Normally it's 276 bucks. Pretty good score.
I figured I'll have the loader on the float detent valve, curl on the next, and the third I'll either plug for now or I was thinking of adding some pioneer fittings so I could run hoses to the front or rear if I ever get anything in the future, grapple or hydraulic top link or whatever, who knows.
