Does Roundup go bad?
   / Does Roundup go bad? #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
Had a quart of the generic concentrate (41%) roundup from TSC. Maybe 12 oz left, a little less than a year old, in original container with tight lid, stored in my garage so it went thru hot and cold.
Mixed 4oz in 2 gal water in pump sprayer & did around my house. Couple days later, everything I sprayed was healthy & still growing. Hmmm.....maybe I remembered dose wrong so did remaining 8 oz in 2 gal water and sprayed again. Everything still just thriving.
I'm guessing the stuff went bad. Seemed the same as when new from appearance & smell, but had 0 effect on the stuff I sprayed around the house. I used it to kill off the areas I turned into pumpkin patches last summer. Worked fine doing the initial killing off of that ground cover, but can't tell I've sprayed anything - twice - over past week with it.
   / Does Roundup go bad? #2
I've had some stored for years with no issues, even after it started to separate and get clumps of gel in it. The biggest thing that affects it is how well the plants absorb the spray ( I always use a surfactant now) and how fast the plants are growing. If not growing aggressively it takes a long time to affect plants, if at all. That's why some instructions say to mow the area and then spray a week or so later, since mowing encourages new growth.
   / Does Roundup go bad? #3
I'm nursing a 2.5g jug of the same 41% from TSC from 2017, used it fine all last year. Will finish it up in the next tank though.
I've had quick success with it, as well as taking nearly a week for any discoloration or wilting to occur. I would mark it to the high amounts of rain we've had, along with the temps not stabilizing here above 50 degrees at night affecting plant growth. I mean it was 30 again this morning and high of 45???
   / Does Roundup go bad? #4
I've never had issues with it and I store it in my shed where it goes anywhere from 95 degrees in summer to below zero in winter. I just shake it up before I mix it and no problems. I don't usually noticing effects on plants until 4-5 days after application but it depends on how fast the plants are growing as Ford850 said.
   / Does Roundup go bad? #5
Usually need 7-10 day to show signs of kill ( don't believe 24 hour burn down statement on container) .... But you will notice a slight color tinge change in 3-4 days....
I am using year old 41% and it is fine.....
Dale
Thanks. Maybe I'm just impatient. Not a big roundup user, but thought the large areas we killed off to plant last year got dead pretty quick. Maybe just the type of vegetation there or being warmer/drier time of year.
But good to know - cheaper to get a bigger jug this year, but was afraid if storing over winter ruined it would be wasteful.
   / Does Roundup go bad? #7
Yup. Usually can get the 41% in 2.5G for $40.
   / Does Roundup go bad? #8
It doesn't go bad, but it takes 10 to 14 days to really show die down.
   / Does Roundup go bad? #9
Best and safest way to use it is to cut and paint the stump with concentrate.
I've never had concentrate go bad. Mix will get stringy stuff in it, which you can fish out to not plug your sprayer.
Ralph
   / Does Roundup go bad? #10
what do you use as a surfactant
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
197390 (A50459)
197390 (A50459)
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
1991 International 4900 Box Truck (A51039)
1991 International...
CAT D6D (A50854)
CAT D6D (A50854)
