Does Roundup go bad?
/ Does Roundup go bad? #1
CMV
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
Had a quart of the generic concentrate (41%) roundup from TSC. Maybe 12 oz left, a little less than a year old, in original container with tight lid, stored in my garage so it went thru hot and cold.
Mixed 4oz in 2 gal water in pump sprayer & did around my house. Couple days later, everything I sprayed was healthy & still growing. Hmmm.....maybe I remembered dose wrong so did remaining 8 oz in 2 gal water and sprayed again. Everything still just thriving.
I'm guessing the stuff went bad. Seemed the same as when new from appearance & smell, but had 0 effect on the stuff I sprayed around the house. I used it to kill off the areas I turned into pumpkin patches last summer. Worked fine doing the initial killing off of that ground cover, but can't tell I've sprayed anything - twice - over past week with it.
/ Does Roundup go bad? #2
I've had some stored for years with no issues, even after it started to separate and get clumps of gel in it. The biggest thing that affects it is how well the plants absorb the spray ( I always use a surfactant now) and how fast the plants are growing. If not growing aggressively it takes a long time to affect plants, if at all. That's why some instructions say to mow the area and then spray a week or so later, since mowing encourages new growth.
/ Does Roundup go bad? #3
I'm nursing a 2.5g jug of the same 41% from TSC from 2017, used it fine all last year. Will finish it up in the next tank though.
I've had quick success with it, as well as taking nearly a week for any discoloration or wilting to occur. I would mark it to the high amounts of rain we've had, along with the temps not stabilizing here above 50 degrees at night affecting plant growth. I mean it was 30 again this morning and high of 45???
/ Does Roundup go bad? #4
I've never had issues with it and I store it in my shed where it goes anywhere from 95 degrees in summer to below zero in winter. I just shake it up before I mix it and no problems. I don't usually noticing effects on plants until 4-5 days after application but it depends on how fast the plants are growing as Ford850 said.
/ Does Roundup go bad? #5
Usually need 7-10 day to show signs of kill ( don't believe 24 hour burn down statement on container) .... But you will notice a slight color tinge change in 3-4 days....
I am using year old 41% and it is fine.....
Dale
Thanks. Maybe I'm just impatient. Not a big roundup user, but thought the large areas we killed off to plant last year got dead pretty quick. Maybe just the type of vegetation there or being warmer/drier time of year.
But good to know - cheaper to get a bigger jug this year, but was afraid if storing over winter ruined it would be wasteful.
/ Does Roundup go bad? #7
Yup. Usually can get the 41% in 2.5G for $40.
/ Does Roundup go bad? #8
It doesn't go bad, but it takes 10 to 14 days to really show die down.
/ Does Roundup go bad? #9
Best and safest way to use it is to cut and paint the stump with concentrate.
I've never had concentrate go bad. Mix will get stringy stuff in it, which you can fish out to not plug your sprayer.
Ralph
/ Does Roundup go bad? #10
what do you use as a surfactant
/ Does Roundup go bad? #12
I don't think it ever goes bad...if it did..I think all the cancer it is responsible for would be drastically reduced.
/ Does Roundup go bad? #13
I use 41% RoundUp to control invasive Glossy BuckThorn in a problematic area. Cut and squirt method. It seemed to become less effective after several years and I asked the exact same question on a foresters forum. Interestingly I was told that it does not go bad with age. But there is a big problem with it - if used repeatedly in the same area the target plants develop a RoundUp tolerant strain relitively quickly and it was advised not to use it for repeated applications in the same area.
gg
/ Does Roundup go bad? #14
I use the HDX 41% 2.5 gal concentrate. Makes 200+ gallons at a fraction of the name brand stuff. Takes me about five years to use a jug, stored in a garage in PA. Takes a week to work, but it always works.
Just found a new jug at HD on closeout for $29. Assume it was old stock, but I have high hopes
/ Does Roundup go bad? #15
Ralph
:thumbsup: . . . yeah, the stringy stuff that plugs up your screen in your sprayer head . . . I use the most concentrated . . . still gets "stringy stuff" in the head, no problem clean it out and go along with your day.
/ Does Roundup go bad? #16
Dish-washing liquid soap has always worked for me on a big job with the pump sprayer.
Otherwise I just use a 'cap' full or two + water in a reusable (original) spray bottle and 'hit' the centre of the plant stock, down low. Either way, 5-10 days 'til it's dead or dying.
Patience, I keep telling myself.
/ Does Roundup go bad? #17
You aren't supposed to let it freeze but I don't know what the result would be. I've used some three years old, but never frozen, and it works just fine.
/ Does Roundup go bad? #18
Roundup does not kill as fast as 2-4D does. If you are getting real fast kill with Roundup normally is a burn down and not a real kill. Real kill takes longer, burn down often kills leaves and not the plant.
/ Does Roundup go bad? #19
For the years I've used Roundup (a long time!) it has always been stored in my unheated garage and temps around here go down to -20 for a week at a time. Of course, I've never looked in the jug to see if the concentrate froze. But I've used Roundup that was 5 years old that was still just as effective as it was new. And I'm another one of those who has never seen Roundup kill anything in 24 hours. I usually see wilting a few days later but the plant doesn't appear to really be dead until nearly 2 weeks have gone by.
/ Does Roundup go bad? #20
What was the temp when you sprayed?
It usually works best above 70 degrees. It will still take time.
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A62130)
2008 GMC C7500...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
VERMEER S725TX STAND ON SKID STEER (A62129)
VERMEER S725TX...
