Does Propane go bad?
   / Does Propane go bad? #1
HawkinsHollow
Veteran Member
SE TN
Branson 3015R
I have a 100 pound tank that I inherited with my property 4 years ago. No idea how long it had been sitting there before I bought the place. It has maybe 40 pounds of propane in it. My gut tells me that I am good to use it, but my question is... Does propane go bad? Discuss!
   / Does Propane go bad? #3
The propane should be just fine. Propane can last years. But do a visual on the tank to insure no rust and good integrity of the tanks valve.
Thanks y'all! Yeah tank looks fine, but I will inspect bottom closer to make sure.
   / Does Propane go bad? #6
How old is the tank? If you inherited it the tank may be many years old.
It can't be that old, because it is in pretty decent shape. I've had it 4 years and quickly got it out of the weather.
   / Does Propane go bad? #8
Wish I could say the same, I have two 100 pounders on my property left by the former owner. Might have to hike up there and take a gander at them. ;-)
   / Does Propane go bad? #9
If you are a fuel seller then yes it goes bad..and you need to buy a new tank every 10 years.
   / Does Propane go bad? #10
You can also get the tank recertified. Most folks just don't bother and just buy a replacement at a higher cost than recertification.
2001 Sterling L7500 Dump Truck (A48081)
2001 Sterling...
2020 MOROOKA MST1000VD Crawler Carrier / Dumper (A47371)
2020 MOROOKA...
More info coming soon! (A48081)
More info coming...
2017 INTERNATIONAL MA035 (A48992)
2017 INTERNATIONAL...
Kubota M5-111 Tractor, Open Rops, Brush Cage  (A47371)
Kubota M5-111...
10-16.5 Forerunner SKS1 Tires (set of 4) (A49251)
10-16.5 Forerunner...
