Does not shut off
/ Does not shut off #1
dcr2002
bluff dale, tx
Kioti Ck25
I have a 2004 CK25H that all of a sudden will not shut off when the key is turned to the off position. I hat to assume that it is the switch if there are other possible things that could cause this. Any thoughts?
Thank you
DCR2002
/ Does not shut off #2
Thank you
DCR2002
Fuel shut off solnoid or relay
/ Does not shut off #3
yep.. I would agree, sounds like the fuel shutdown solenoid or relay is faulty.. or the wiring between these devices
/ Does not shut off #6
Your problem could be 1. a sticky idle control in your pump, or 2. a bad shutoff solinoid 3. a bad wire or fuse 4. a bad key switch. Covering the air intake will shut it off for sure but, since that is not how it was designed to be shut off I would want to know why.
The first I would do since your machine has an electric shut off is check the fuse. After that.
Do you know where your injector pump is? If so on the govneor is where the fuel shut off solinoid is, is there a manual shut off there also? If so that will save you from dashing to the air filter intake to stop the engene. Since the key shut off did not work you may have sticking parts inside the injector pump, try this.
On top of the govenor usually is a vent, under the vent cap should be a nut (about 15mm give or take) that is your lube oil fill hole. On the far end of the pump on the bottom is the lube oil drain. Usually about 1/2 way up the pump above the drain is a bolt with a tiny downward tube, the tube may or may not be covered with plastic if it is covered remover the cover, that is the over fill (if you over fill the pump the excess lube oil drains from there).
Drain the oil from the pump (save it and measure to know how much to replace). Pour that measured amount of diesel in the lube oil fill hole and run the tractor for a minite and try to shut it off with the key, if it shuts off good if not cover the air intake to shut off the engine.
Now drain the deisel from the pump and replace it with the same oil that you use in your engine. Whenever I change my engine oil the injector pump also gets an oil change.
If the key switch did turn off the engine :thumbsup: If not call your local deisel guru explain what you have done and he should know where your problem is.
/ Does not shut off #7
More than likely, it's the fuel solenoid or power to it. Some members have had problems with their ignition switches causing the same or sometimes the opposite where the solenoid doesn't open the fuel. If you don't have an extra manual shut off, the solenoid is just in front of the injection pump on the right side of the engine. You can grab the lever by hand and move it to shut down.
/ Does not shut off #8
I have a DK 35 and it has a pull cable near the key to manually shut down the engine. I have had problems like your's before. My fuel relay is fed from the fuse that also controls emerg flashers, I pulled that fuse to check something while engine was running and discovered I could not use key to shut down. I have also experienced problems with the fuel linkage inside the engine compartment. If you followed the cable from throttles (both foot and hand controlled), it comes to plate and then a pivot point, mine was sticking where the stationary "peg" meets the "U" shaped cam-like wheel. A bit of grease and all was well after that. In fact, I have had problems with the clip retainers on the fuel linkages that have shifted a bit and then got hung up at a position other than the lowest throttle setting.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2022 EZ-GO ELITE...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
Year: 2016 Make: Kia Model: Sorento Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 112,757 Pla... (A64557)
Year: 2016 Make...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
