Does haying really take that much power ?
   / Does haying really take that much power ? #21
Tractor, we don't need no stinking tractor!
   / Does haying really take that much power ? #22
Just to clarify, A dozen years ago, I was baling with 2 wagons behind the baler, the idea being to kick them into the rear wagon and then fill the front wagon. While turning around under my 4400V service lines, a bale kicked up perfectly and snagged in one of the lines. It caught fire from contact with the ground line. I let it burn out, making sure the field didn't catch from the ashes dropping down, but the black marks on the wires are still there after all these years..
I used the EZ Trail bale baskets. Had the big tailgate and dumping features.
   / Does haying really take that much power ? #23
   / Does haying really take that much power ? #24
My round baler 4 x 5 is actually require less PTO hp then a square baler, yeah ok it heavier to pull up hill with a full bale in it but still 60hp is plenty for both its just odd when you see the hp requirement for a round baler its way over estimated...
I agree. My 35 hp JD easily rolls my 4x4 variable chamber bales while running in 2nd range, 3rd gear. These weigh more than the 4x5 bales I struggled to make with my Vicon 1210 fixed chamber machine. So, the process is a large factor in this power requirement. As for comparison with square baling, I never was able to run this ground speed on my JD 14T. 1/3 the wall-clock time with the 335 to do the same field.
   / Does haying really take that much power ? #26
For small sq-bales, 20Hp to 40hp tends to work well enough on flat fields. Cut, rake, bale does just fine. The only drawback is, it takes way longer vs a 40 to 8-Hp tractor.
My Pa cut with a Ford 8N and sickle blade, then bar raked, and used an old reddish New Holland two digit model baler. I was too young to know much about the equipment details.
   / Does haying really take that much power ? #29
I think it will depend on what type of bales you plan on bailing.
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
2020 DRAGON ESP...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
CAT D8 (A58214)
CAT D8 (A58214)
2011 KENWORTH T370 (A58214)
2011 KENWORTH T370...
