sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,706
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
As already mentioned, I use an 8 ft heavy landscape rake in draft control on either an L4300 or MX5100 to smooth land and fields and can do a truly perfect and flat job. People are amazed how flat it is and I do that by gradually raising the rake off the ground and by feathering the draft control. There is a learning curve to this and the ground has to be prepped first. It has to be worked, packed hard and then preferably rained on to settle it out. I would never or rarely put the full weight of the rake on the ground because it might bounce. My goal is merely to level. I would also rake the field multiple times and in different angled directions.
The purpose of working and packing the ground is to bury rocks and trash and leave the soil soft on the surface so a light touch scrapes the high spots easily.
I have only used a blade occasionally and not recently but can't see any reason why that would not work similar to the above. I would not put full weight of the implement on the ground, the ground would be harder rather than softer and I will have to alter directions to keep things smooth. It won't come out as smooth as a rake because material will spill to the sides but I think a respectable job could be done using draft control and experience. I don't see how ridges would develop with an experienced operator and correct soil conditions. Maybe in corners or areas difficult to turn.
Lighter tractors like I use (3500 lbs) do a better job than a heavier one (8000 lbs) is my experience. Other soil types may not work like mine so this is just my two cents on all this.
