Does B7800 have and unused rear circuit for sprayer use?
   / Does B7800 have and unused rear circuit for sprayer use? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I want to mount my small 15 gal spot sprayer to the back of my B7800 on a small 3-pt hitch platform. Is there an unused circuit I can use in the back of the tractor for power? Perhaps an unused circuit for a worklight?
   / Does B7800 have and unused rear circuit for sprayer use? #2
The only circut in the rear is over by the rh fender, both power and ground. By the rops
   / Does B7800 have and unused rear circuit for sprayer use? #3
For what it's worth, a person not far from where I live did the exact same thing with his 2410. Since he already had a rear work light tied into the unused plug/circuit at the back of the tractor, he ran (neatly) a lead from the battery with an inline fuse to the back of the tractor. He then installed a toggle switch and plugs for the sprayer pump (the whole spray unit is mounted to a 3 pt platform). Pretty neat set-up and he's been using it for years.
The rear mount is what I have been thinking and I planned to just hook to the lead for the work light. I could also make a small bracket to hook to the front tractor frame--weight bracket--and go with a fused but direct hookup to the battery. I plan to remove this when not using.
I figured I could have a shop bend a pice of maybe 3/16 steel so the bracket just slips over the front of the frame--no bolts--and un-slips when done. Like a frent end weight.
I will spray only three or four times a year so this would work?.
Polaris 90 Sportsman 4-Wheeler (A50121)
Polaris 90...
Wolverine Mini Skid Steer Combination Bucket (A50515)
Wolverine Mini...
1990 GMC Topkick Grain Truck (A50514)
1990 GMC Topkick...
Unused 2025 CFG Industry MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2015 Ford F-150 4x4 Crew Cab Pickup (A50323)
2015 Ford F-150...
