Does anyone have one of these blades?
   / Does anyone have one of these blades? #1
BubbaJr
Platinum Member
Western Ohio
2016 KUBOTA B2650 w/cab & A/C
It's a frame mount apparently. I was wondering if you can raise, lower, and angle the blade hydraulically. The tractor I'm getting does not have a quick attach mounting, and it wouldn't make sense for me to go that route.
Thank you,
Joe
   / Does anyone have one of these blades? #2
Hard to tell for sure with that photo and without a part number, however if it is like my Kubota snow blade it does.
My snow blade connects to the frame using two pins and some bolts that wedge the slack out.
It connects to the FEL valve. You can raise/lower and angle the blade left/right to discharge on the left or right. You can't rotate to change levelness.
Thanks RJ,
How does it work with snow? And does it have adjustable shoes on the back side?
Thanks again,
Joe
   / Does anyone have one of these blades? #4
I built one similar to that and it works great in snow!:thumbsup: I do have to run tire chains to push uphill well.
   / Does anyone have one of these blades? #5
I have similar blade for L3940. Works great in snow if you have ballast on 3 point. Never used it in dirt. Philip.
Thanks for that info. I assumed (I know) that the plow mounted to the plate on the front of the tractor. I had no idea that the frame was such a substantial piece of hardware. How difficult is that to mount and dismount?
Thanks, Joe
   / Does anyone have one of these blades? #7
Thanks, Joe
Use FEL hydraulic control to raise and lower to assist putting it on. 2 big pins in front, 2 medium size pins mid mount, those are pretty easy. The hardest part is lining up the drawbar, sometimes you have to kick rear of frame to one side or the other. Not too bad, 10-15 minutes as it lays there in the dirt, if done on concrete floor, little quicker. Once I put it on in winter, I rarely take it off until spring. Philip.
Just looking at it, I didn't think it would be a quick connect. :) Thanks Philip
Joe
   / Does anyone have one of these blades? #9
Those blades are designed for snow and skid shoes are an option. They do not recommend using the blade as a dozer, on moving light weight material. I have the mounting kit but not the blade (got it at a bargain on speculation). The same frame mount is used for the rotary brush and I think the front mounted snow blower as there is a PTO kit from the MMM that is another kit. Some day I may by the blade ($$$). The blade is available with either manual or hydraulic angling.
Ron
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2018 WACKER NEUSON RD28 120 DOUBLE DRUM ROLLER (A51242)
2018 WACKER NEUSON...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
New Holland TN60A (A50120)
New Holland TN60A...
2002 Winston ProSeries 20K Tandem Axle Equipment Trailer (A47384)
2002 Winston...
