Does a 4720h have a clutch in the transmission?
   / Does a 4720h have a clutch in the transmission? #1
bigrich954rr
Bronze Member
oregon
branson 4720h 6ft brush hog ,post hole digger, ripper, pallet forks,
A 2016 Branson 4720h does it have a clutch in the transmission ? Using Tractor in 3 gear a lot will that wear out the trans faster I can hear it bypass hyd fluid some times?
Or is it like a car with a Torque converter
   / Does a 4720h have a clutch in the transmission? #2
It isn't like a torque converter. It's probably a lot like a very large hydraulic Orbit motor.
Lots of pressure bypass operation heats the fluid, and makes the engine work excessively hard, wasting fuel and increasing wear on drive components.
You should not be experiencing this in normal working conditions., if so, select a range or two lower.
Ok thanks my land has a lot of hills and raise spots so it like from flat land up a small hill to next flat some times I would hear it bypass for a sec just as it comes over the crest . But I'll drop it down a gear to cut the wear down .
Thank you
7033 (A51691)
7033 (A51691)
2016 CATERPILLAR D3K2 LGP DOZER (A56129)
2016 CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
