Does a 4720h have a clutch in the transmission?
   / Does a 4720h have a clutch in the transmission? #1
bigrich954rr
oregon
branson 4720h 6ft brush hog ,post hole digger, ripper, pallet forks,
A 2016 Branson 4720h does it have a clutch in the transmission ? Using Tractor in 3 gear a lot will that wear out the trans faster I can hear it bypass hyd fluid some times?
Or is it like a car with a Torque converter
   / Does a 4720h have a clutch in the transmission? #2
It isn't like a torque converter. It's probably a lot like a very large hydraulic Orbit motor.
Lots of pressure bypass operation heats the fluid, and makes the engine work excessively hard, wasting fuel and increasing wear on drive components.
You should not be experiencing this in normal working conditions., if so, select a range or two lower.
Ok thanks my land has a lot of hills and raise spots so it like from flat land up a small hill to next flat some times I would hear it bypass for a sec just as it comes over the crest . But I'll drop it down a gear to cut the wear down .
Thank you
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55314)
2023 New Holland...
2020 Kinze 3505 High Speed 6/11 Planter (A55314)
2020 Kinze 3505...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
