dodge ecodeisel or ford f150 ecoboost
/ dodge ecodeisel or ford f150 ecoboost #21
My wife got a Ram ecodiesel truck last summer when our old Sierra crapped out. I was lobbying for the Ecoboost, but she never even got around to a test drive, after trying the Ram. With only about 8000 km, she is getting just over 10 l/100km (roughly 23mpg); this drops to about 13 l/100km (18 mpg) when we tow the 2-horse trailer. Although the Ram is quite comfortable and does fine for our uses, I think the ecoboost would have been a much more competent towing vehicle, overall.
The smaller Ecoboost might be a better comparison to the Ecodiesel...what do others think?
The torque of the ecodiesel is impressive, but it falls short on HP...the ecodiesel is 240hp/420fp vs. 325hp/375fp for the 2.7l ecoboost and 365hp/420fp for the 3.5l ecoboost. The horsepower difference is significant in acceleration, passing, maintaining speed on a grade, etc.
/ dodge ecodeisel or ford f150 ecoboost #23
I had high hopes for the ecodiesel, and even test drove one with serious consideration of trading my 14 Hemi for it. Unfortunately the up-charge is even worse in Canada, $5700 over the v-6 gasser and $4500 over the Hemi... which prompted me to write a cheery letter to Fiat Canada consumer affairs. Their reply was along the lines of " we can charge it, so we will ".
Then there have been some real horror stories of catastrophic failures with a large enough number of trucks to make you wary.. No parts, no replacement engines and sometimes months of waiting for your brand new truck to be fixed...
I'm still considering it for next fall maybe. Hopefully they have sorted out the bugs and supply problems by then.
Btw, they will touch 30 mpg in steady highway driving.... which is all I do.
/ dodge ecodeisel or ford f150 ecoboost #24
The Nissan is very interesting but the reviews are only showing 17-18mpg. My duramax dually is getting 16. Not much improvement. I have read some stuff on the ram eco diesel in the30mpg range.
/ dodge ecodeisel or ford f150 ecoboost #25
Farmboy00. ...It looks like you are basing your bias against GM on older vehicles. I hope you realize that GM had new design start in 2014 , they ride great (better than my last two Dodges) and the 5.3 litre V8 gets better overall gas mileage than the Ford 6 cylinder. I too wanted the Dodge Ecodiesel , but the dealers around here were given one each (all the rest were the typical hemis) and the Ecodiesel was a shorter box than I wanted and dressed up too much. So be prepared that they might not have in stock a lower base model. Whereas at the Chev or Ram or Ford dealer in gas models you will have way more choices. I like the simplicity of a reliable good gas mileage V8 . and a double cab with 6ft box. so I went with 2014 GMC Sierra (one model up from base model) 18 months ago, zero problems so far.
/ dodge ecodeisel or ford f150 ecoboost #26
I don't understand people settling for what they can find in the lot. Order a vehicle the way you want it. If you want a base model order a base if you want top of the line order that. If you settle for less than what you want when buying it's more common for people to trade early because they were never truly happy with the vehicle.
/ dodge ecodeisel or ford f150 ecoboost #27
I didn't settle, there was enough choice around that I got what I wanted , at time when I needed the vehicle. I needed to trade in the other one because it was due for big expenditures, if I would of had to wait two or three months for ordered truck I would of been hit with repairs I wanted to avoid, many others feel the same, or maybe lease ends and you need to make decision etc etc. Besides I think you get better deal off the lot in many cases. I wanted the one up from base model, so I got the 4 x4 lever on the floor (not switch knob on dash) and not as many gadgets I don't need to learn how to use.
Honestly that's what he wants. Base line really.
But for the gmc and Chevy. We haven't look at newer then 2014 cause they are out of his price range. Haven't even looked at that new of ford's. Only looked at new dodge cause you can get little to no interest from dodge. They are the only ones that have advertised it. And mostly gmc and Chevy was ruled out because of comfort. If they have changed they way they ride since 2012 we haven't heard. He really needs comfort spending multiple hours a day driving.
Anything besides dodge he looking at is used so he is willing to settle. Just needs to have 4x4, at least a 6ft box, good gas milage, needs to be ext. Cab or bigger and on budget
/ dodge ecodeisel or ford f150 ecoboost #29
With a name like Dodge Man, I'm going to say the Eco-diesel is the way to go. Its a good choice if you aren't hauling heavy loads or towing heavy. On the other hand, it sounds like you are throwing out the Chevys and GMC's based on some kind of past experience. I have been exposed to all of the big three from my job and personal use and can't say there is a big difference between the comfort of any of them. I also can't believe they would be out of your price range, the Eco-diesel seems to by on the high end of cost for a 1/2 ton pickup.
/ dodge ecodeisel or ford f150 ecoboost #30
The ecodiesels have less than 1,000lbs of payload. That is pathetic for a truck.
/ dodge ecodeisel or ford f150 ecoboost #31
I bought a 2015 F150 5.0L V8 last September. I test drove the ecoboost(s) and didn't care for the turbo lag. The 5.0 just moves when you press the pedal.
/ dodge ecodeisel or ford f150 ecoboost #32
True - but depends what you buy it for. There isn't anything on the market with a higher payload that can get 30mpg. If you need a true work truck get a 3/4 ton but the eco diesel fills a niche.
/ dodge ecodeisel or ford f150 ecoboost #33
In theory you're right. But in reality you buy a truck to be a truck, otherwise just buy a car or SUV if you're only requirement is MPG. A diesel truck, no matter what the intended purpose is, needs to be be able to tow and haul stuff at the end of the day.
I saw an ecodiesel, towing on it's bump stops, a small trailer with two snowmobiles the other day. The small trailer just looked to be overpowering the truck. Dodge/Ram/Fiat needs to address that one glaring issue they have with this platform, otherwise it's going to fail trying to cater to a small niche market.
/ dodge ecodeisel or ford f150 ecoboost #34
Rear air bags would eliminate towing on the bump stops.Some folks are to cheap to purchase them.I have the firestone bags on my 2006 Ford f150 super crew and would not be without them.
/ dodge ecodeisel or ford f150 ecoboost #35
So the guy that needs a truck to go hunting with all his tree stand stuff, or duck decoys or any other dirty but light loads , by your book should buy a car or SUV because trucks are reserved for your demographic only !...........hmm , I think that is rather closed minded , and considering those eco diesels are selling very well, I guess there are more niche uses for a truck than just your heavy needs. I myself need half way between light stuff and heavy stuff, for my hobby farm uses , sometimes it has 1000 lbs of lumber or fence posts , sometimes it is towing a tractor, sometimes it has 300 lbs of bulky Christmas gifts for grand kids........so went with GMC 1500 4x4 V8.....to each his own
/ dodge ecodeisel or ford f150 ecoboost #36
Your not in the, "my only requirement is MPG" niche, which I thought was the topic at hand. Not quite sure the point your trying to make here?
/ dodge ecodeisel or ford f150 ecoboost #37
Not completely true. My daily driver is a 2000 Chevy 1/2 ton. The hauling and towing capacity is pretty low, but I hardly ever haul more than 1000 pounds in it. I have a 3500 dump for heavy hauling and a F-350 for heavy towing. I commonly haul fuel cans and chainsaws. That stinks up an SUV. If I need to haul firewood to the house ( usually 1/2 rick at a time ) that would make a mess in the SUV,
/ dodge ecodeisel or ford f150 ecoboost #38
I beg to differ, my Volkswagen Jetta has achieved 50+ mpg and has a payload of 1193 lbs, the parent's Passat has a payload of 1250 lbs and regularly sees 45 mpg....the ecodiesel isn't going to get 30mpg.
On second thought, I guess you are correct.....if I drive the piss out of my Jetta I can only achieve 40 mpg.....it is incapable of getting 30 mpg
/ dodge ecodeisel or ford f150 ecoboost #39
Many have got 30mpg.
Well interesting debates. It still won't be at least a month maybe to this summer till we decide.
But the truck will be carrying 1,000lb of tools everyday 7 days a week. And tow a est. 12 ft or smaller trailer a day or 2 a week with around a 1,000lb.
Like I said before the only reason looking at ecodeisel is milage but if they can't handle that it's useless.
Have heard mostly good about the ecoboost, a lil bad but mostly that they are beasts.
Like I also said we ain't looking into heavy on the Chevy or gmc but are still looking at them. But for what we have found around here to us are overprice. He ain't much to Chevy but has owned them but can't get comfortable, and even a 2012 rides like a car. And that is what year he would look at
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
Willmar Wrangler 4500 Loader (A66285)
Willmar Wrangler...
Husqvarna YTH24K48 Riding Lawn Mower (A65579)
Husqvarna YTH24K48...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
6' 3-Pt Disk (A66285)
