Do you use your tractor in a fenced in Garden?
   / Do you use your tractor in a fenced in Garden? #71
I wonder if that would work sprayed onto rags and tucked under the hood of the tractor to keep mice away.... Or would it attract them?
For the garden I just use an electric wire and fence charger. Have not tried that on the tractor... the tires would insulate the metal from the ground so that part is easy, but a mouse would have to be tall enough to touch the tractor body and the ground at the same time to get shocked. A mouse the size of a deer..... or a bear. Scary thought.
rScotty
According to this, it will. Only one way to find out.!!
Peppermint Oil​
Many natural rodent repellents contain peppermint oil because the strong scent can disorient rodents. As a result, mice and others will avoid the smell. If you want something other than a pre-made peppermint-scented repellent, you can use scented cotton balls or create a water and peppermint oil spray.
   / Do you use your tractor in a fenced in Garden? #72
This is exactly why I bought a BCS two wheel tractor.
   / Do you use your tractor in a fenced in Garden? #73
my 4.5 acre garden is fenced with standard woven wire,---had to do that to keep coyotes out,--- they destroyed the sweetcorn one year. deer dont jump the fence, too lazy I guess. ---got lucky on that.
Nice. I really dislike coyotes!!
Do you actually call a 4.5 acre plot a “garden”?
My wife gardens a 1/4 acre area (wire fence) and I think that is a ton of work!!!
We use a tiller - maybe that’s the issue!
   / Do you use your tractor in a fenced in Garden? #74
I did the deer battles for years and, starting with motion activated lights and sprinklers, chaining dog in garden at night, electric fencing, baited electric fence; all to no avail. I gave up and finally constructed an 8’ woven wire fence about 6 years ago. No problem since then. A lot of work but a permanent solution. Yes I did leave a tractor turn around strip around the garden, and also included the orchard in the fenced area. About 1.5 acres between the garden and orchard. Yes I do have to mow inside the fence.
   / Do you use your tractor in a fenced in Garden? #75
Anyone know what happened to the OP? Looks like he hasn't been on in over a year.
   / Do you use your tractor in a fenced in Garden? #76
Yes I do a 4.5 acre garden. Donate all but a small amount to the Midwest Food Bank.
   / Do you use your tractor in a fenced in Garden? #78
Coyotes and deer hop over mine easily and often, according to my cameras. The garden itself has 5ft fencing with a wire about 8in higher. No jumpers.
Bruce
   / Do you use your tractor in a fenced in Garden? #79
Nothing has gone over mine since I put it up 10 years ago.
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
2016 PETERBILT 579 SLEEPER (A59575)
2016 PETERBILT 579...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
