Do you leave implements outside??
/ Do you leave implements outside?? #21
Hi,
My backhoe stays inside with the tractors. I also hang my PHD inside as it does not take up much space.
Things like the box blade, landscape rake, dirt scoop, sub soiler sit on some 2x4s up off the ground and that is about it.
My Woods rotary cutter...well...it has a little roof built over it. Not sure if it should be considered kept outside or not. The cover keeps the snow and most of the rain off it. See attached photo.
I do plan on making a different set up at some point in the future, some kind of little roof that would hinge up when I need to remove the brush hog, and which would lower back down after I put it back.
Works for me! /forums/images/graemlins/blush.gif
/ Do you leave implements outside?? #22
I have only a rake that is totally exposed, BH is on a dolly in the shop and everything else is under an awning off the side of the shop.
/ Do you leave implements outside?? #23
The only implement that stays outside for most of the year is an ancient rear blade I bought for $60.
The mower or cutter might be left out for a week or so...the tractor for a few days, but otherwise, all the gear is in the garage or outbuilding.
/ Do you leave implements outside?? #24
I try to keep everything under a roof. If anything sits out its my rear blade, but thats only on occasion. Some of them set in a open cattle barn. I would try to keep the PTO equipment in and anything that has a lot of moving parts like my planter. My Father in law parks everything in the pasture except his tractors and has real good luck with everything. I think parking them inside makes a big difference when you get ready to trade them off. As we grow and equipment gets bigger I may have to move things outside too.
/ Do you leave implements outside?? #25
I bought 10' x 20' tent canopies at a Pep Boys sale for $79 ea. The side enclosures cost andother $79 ea. Got 3 to keep the tractor and all implements in them and a 4th for my tool room.
I'll need them while building the house. The county won't let me build the barn/workshop first for fear I may live in it! What a crock. So now I live in the canopies. /forums/images/graemlins/cool.gif
/ Do you leave implements outside?? #26
I try to keep as many of my impliments inside as the space allow. The only one stay outside is the drag harrow so far.
/ Do you leave implements outside?? #27
Box blade and 1 row culitvator always outside.
Tiller in the barn. Rotary cutter sometimes in/sometimes out. It stayed this winter cause I used it late in the fall, otherwise I'd put it up.
/ Do you leave implements outside?? #28
I have some implements setting outside.. like a pasture drag, old disc, and my plow.. Other stuff is under the barn or lean-to, or under a tube frame -tarp structure.
soundguy
/ Do you leave implements outside?? #29
Well, I'm kinda keeping it in my hip pocket for future use ... near future use I hope. The only problem is that because she can say it in 5 minutes, she thinks I "can get 'er done" in the same timeframe.
/ Do you leave implements outside?? #30
</font><font color="blue" class="small">( The only problem is that because she can say it in 5 minutes, she thinks I "can get 'er done" in the same timeframe. )</font>
Did we marry sisters?
Are the security alarms the dealers use available reasonably for us common folk? I want to secure my implmenets outside.
/ Do you leave implements outside?? #32
I also don't have an "inside" yet. Hope to remedy that this summer, but I have to find a builder to build my shop first.
As far as theft goes, I think everyone on my street has a CUT and 80% of them are kept out or in a 3-sider in plain sight. A thief would probably get stuck anyway trying to get my tactor out of my field. I guess I keep it kinda behind the house, but that's it. I don't leave the key in it or anything.
I did get one of those 8X20 storage containers to keep stuff in. I thought about getting a 40 ft one... at 10 ft high I could park in there, but I didn't think the cost nor the eyesore factor would be worth it.
Also, I asked the dealer about it. They said that all their stuff sits outside. He said a tarp is as likely to damage it as keep it nice (through rubbing or something) so I just leave it out in the elements, along w/ all my other implements (plow, harley rake, cutter, BB)
Case 1845C Skidsteer Loader (A66285)
Case 1845C...
1986 GMC C7000 Fertilizer/Spreader Truck, VIN # 1GDL7D1B8GV512761 (A65563)
1986 GMC C7000...
3 Point Hitch Cultivator (A65579)
3 Point Hitch...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
Metal Goat Family (A65583)
Metal Goat Family...
