Do you have wheel weights?
/ Do you have wheel weights? #1
Lucky_Ducky
MX6000 w/ cab
Do you have wheel weights installed on your tractor?
Have you noticed a difference in performance?
/ Do you have wheel weights? #2
Only in the form of liquid in the rear tires in all of the last three tractors. Works well, and all have been used with RFM's for mowing the yard, snow removal and general loader work. I haven't run without it, so can't provide you with a before and after report.
/ Do you have wheel weights? #4
I agree with RJ. No substitute for weight! Plus wheel weights on tractors to me is like a cool accessory compared to say putting new wheels on a truck or something!
/ Do you have wheel weights? #5
Depends on what you are trying to do with your tractor determines if you see a difference in performance.
Loader work or work requiring traction you will see a difference.
/ Do you have wheel weights? #7
What are you doing with the machine? I've had wheel weights on a few of my tractors, over the years. None on the current machine, but I have the rears filled with fluid. Wheel weights fall more toward the "sprung weight" side of the equation on a tractor, where your only suspension is tire squish. Fluid-filled tires are the opposite, definitely un-sprung weight, with the added effect of reducing air volume and tire squish. Both have their pros and cons.
But there are some applications (eg. flatlands mowing) where added weight is the last thing you want, so it all comes down to your applications.
/ Do you have wheel weights? #8
Nope..... Just 500+ lbs on 3PH... Wheel weight or filled rear tires are just not enough....
20190513_134020-jpg.607788
20190513_134501-jpg.607789
JD weighs in at 520 lbs. according to manual...
/ Do you have wheel weights? #9
I needed more weight, a lot of what I use the tractor for is the loader, or forks. And the rear wanted to lift before I got to the full lift capacity of the FEL assembly when using the forks. I bought one of the commercial ballast boxes, and sat it down at the ready-mix plant so they could fill it with backhaul, or the next time they did precast. Not sure how much it ended up weighing, but the 3-point groans when it lifts it, and the rear still lifted off the ground with a heavy FEL load.
I bought wheel weights which supposedly fit, only to discover the rear wheels aren’t drilled to mount the weights. (lesson learned: Make sure the rear wheels have mount points for wheel weights, before you buy them.)
Then I decided to add liquid ballast to the rear wheels. It cost about what the weights did, but was less hassle than buying new rear wheels, or drilling the ones I have. In retrospect, if the liquid ballast folks had listed the dealer location which did the install when I was first looking into it, I would have gone with the liquid, rather than order the wheel weights. When I first looked into it, the nearest installer was about three-hours away, over the Continental Divide. The newer online listing had a dealership an hour away.
/ Do you have wheel weights? #10
What's keeping the JD in the bucket? Doctored photo, or something we can't see?
I have about 900 lb. of fluid in my rear tires and put another 1500 lb. on my 3ph when making heavy lifts. Did that yesterday for lifting a 1200 lb. pallet of seed and fertilizer out of the back of my truck on uneven ground.
/ Do you have wheel weights? #12
Is it possible to get "very heavy" wheel spacers so that they act as wheel weights plus spacers? This would be for a 2022 Massey Ferguson GC 1723EB.
/ Do you have wheel weights? #13
Not a bad idea, but I've never seen any. Of course you could have a machine shop make a pair, but likely a few thousand dollars for a single pair, given setup time and material at low volume.
<-- has items machined daily for work, but usually aluminum instead of steel, when talking parts of this size.
/ Do you have wheel weights? #14
I have always used liquid filled rears. This time I also added spacers. The combo of added wheel weight and spacers is the cat's meow. ;)
/ Do you have wheel weights? #15
Wheel weights are good for plowing, snow blowing, pushing or pulling, but weight on the back of the tractor is better for loader work. A load in the bucket will use the front axle as a fulcrum and take weight off the rear of the tractor. Weights and loaded tires will counter this, but not as good as weight out back. Weight out back will use the rear axle as a fulcrum and help ease the strain on the front axle.
If your plowing snow, weights and loaded tires are your best bet. There is no weight out front when plowing or snow blowing because the implement is on the ground. In this case weight out back can affect your steering and make it a bit light. Wheel weights and loaded tires plant there weight right over the rear axle not affecting steering.
Obviously, the bigger the tractor, the less you will notice.
Dave
/ Do you have wheel weights? #16
Wheel weights and fluid filled tires is not a substitute for the counterbalance on the three-point hitch when doing heavy loader work. Without the weight, extending past the rear axle the front axle, which is the weakest axle is carrying most of the weight. To get the weight to transfer to the rear axle you need to add counterweights on the three-point arms.
If you are trying to improve traction the fluid and wheel weights will increase the traction in addition to adding to the stability of the tractor. In most cases, the weights help to lower the center of gravity. The lower the center of gravity, the more stable you are in most situations.
I was using a Massey Ferguson 1528 with a two drum hay cutter. With the hay cutter lifted, as when you are making a turn, the left wheel became very light. I ended up putting on two sets of rear wheel weights, as well as fluid in the tires. This solved the lifting problem very nicely. The problem came later when the rear axle housing cracked on the passenger side. This occurred years after I stopped using the tractor to mow with. Therefore, I can’t contribute the damage to the mower hanging off to the right side, but there is that possibility.
The stability and the traction were greatly improved. And that tractor had the industrial tires on it.
/ Do you have wheel weights? #17
Like having wheel weights as well. Six 1/2 pie weights per side on the rear of the ole Rhino, helps with pushing, digging, or ground engagement as well as loader lift stability. Does push near the load carrying of the 10K trailer when hauling with a heavy implement on the back.
Just moved ~2400lb of solar panels on the forks and the wheel weights do help. Agree with Gee Ray, and above Always have at least 1K on the 3 point as well.
/ Do you have wheel weights? #18
I repurposed these old wheel weights. Dad bought them in 1969 for his JD 140, and then used them on his JD 316 in the picture. I sold the 316 but kept them for the Kubota I bought. They make a bunch of difference in the snow.
/ Do you have wheel weights? #19
Loaded tires and 4 75# weights on each side
/ Do you have wheel weights? #20
No to wheel weights. I have 775 pounds of RimGuard in each rear tire. Just can not get enough weight with wheel weights.
Also have a rear blade - 1000+ pounds.
I do not have weight in the rear wheels and 3-point to leverage weight off the front axle. It's all there to keep my "rear" on the ground when I lift with the grapple & FEL.
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
2013 CATERPILLAR 336EL EXCAVATOR (A60429)
2013 CATERPILLAR...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
