Do you have a drone?
   / Do you have a drone? #111
Getting optional blade guards has saved me on a couple of occasions when I was getting a little too 'cute'.
   / Do you have a drone? #112
You're definitely going to want a second battery that you can charge while flying with the other one. Too much down time otherwise. Obstacle avoidance could be a handy feature for some I imagine. How well it works I don't know. The return to home feature on the 3 can be set to a given altitude and when deployed, the drone will ascend to that height then return home. So as long as it is set high enough for your area, shouldn't be collision issues unless I'm missing something.
All good points.
With further research the obstacle avoidance is only to the front. So would offer minimal protection in cluttered areas such as timber where my concern would be backward or side motion that would cause a collision.
The second battery thing would be a necessity for me I believe. Did yours come with two?
How about the viewing screen? I don't use an I-phone so can't take advantage of that. Do have a tablet. I want a screen large enough to be of value. What are you using?
   / Do you have a drone? #113
Another good point!!!
   / Do you have a drone? #114
All good points.
Android or iOS are both applicable. I tried iPhone 6, iPad and finally settled on iPad mini. For me, perfect size. I also wanted another app called LITCHI which allows autonomous flight planning. Translation is the ability to preprogram a flight path or route and send it out...it does what you programmed it to do and returns. It's easier than it sounds. For me I can fly the perimeter of my property at different heights and look for problems with trees, fences or otherwise. I watch the video feed vs flying the bird.
   / Do you have a drone? #115
Would this also work on the Phantom III Standard model?
   / Do you have a drone? #116
I run the Litchi as well as the DJI GO app on an Invidia Shield 8" tablet with the Phantom 3A (advanced) The Litchi app (around $20 US IIRC) is incredible for autonomous flying as mentioned above. It's easily programmed to take snapshots or video at various locations that you select on the map. The flight path can be saved and then rerun exactly as programmed at a later date.
I have a DJI Phantom 2 Vision+ that I no longer use and probably should sell but it may be a collectors item 50 years from now.
   / Do you have a drone? #118
My very large farmer friend has that ability on his Drone. He uses it frequently to "grid" fields during growing season.
Excuse my IT language deficiencies. So, is my Samsung Galaxy 6 phone compatible with the Phantom 3 Advanced? Thanks!!!
   / Do you have a drone? #120
2020 Peterbilt 579 Daycab Truck Tractor (A50860)
2020 Peterbilt 579...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
METAL FUEL TANK (A50459)
METAL FUEL TANK...
JOHN DEERE 3155 TRACTOR (A50459)
JOHN DEERE 3155...
2007 Case IH 8010 4WD Combine (A50657)
2007 Case IH 8010...
2010 Ford F-550 Bucket Truck, VIN # 1FDAX5GR9AEA21656 (A48836)
2010 Ford F-550...
