Do you grease your tractor's PTO stub shaft?
   / Do you grease your tractor's PTO stub shaft? #1
Anonymous Poster
Epic Contributor
Do you grease your tractor\'s PTO stub shaft?
Hi,
Seems like greasing the PTO shaft of the tractor would be a good idea, unless dirt could get mixed in and cause accelerated wear.
What is the normal practice? Should I or shouldn't I?
I did grease my mid PTO shaft, but that was because I don't have a use for it and wanted to protect it from rusting...
Thanks for any advice!
   / Do you grease your tractor's PTO stub shaft? #2
Re: Do you grease your tractor\'s PTO stub shaft?
I keep it lightly greased and religiously keep the plastic cover on it. The greasing seems to let the pto coupling go on/off a little easier. /forums/images/graemlins/smile.gif
   / Do you grease your tractor's PTO stub shaft? #3
I don't `put grease because it will get dried and gummed up and covered with dirt. What I do is carry a can of WD-40 on the tractor. I always spray the pto shaft and the implement coupler before I put them together. I also use the WD-40 on the third arm and the side tilt threads any time I use them.
   / Do you grease your tractor's PTO stub shaft? #4
Gerard,
I see you are listed as being in Syracuse New York. Are you familiar with a large corporation called Carrier Air Conditioning. I worked for a couple of thier distributors in Minnesota for about ten years. And now I am one of thier dealers selling thier products.
Murph
   / Do you grease your tractor's PTO stub shaft? #5
I put an oil soaked rag in the implement end of the shaft, that helps putting it back on 6 months later. bcs
   / Do you grease your tractor's PTO stub shaft? #6
The best thing I have found is Lock Ease. It is spray graphite. The liquid carrier disolves quickly and leaves
dry graphite behind. Does not attract dirt/dust etc. Works good on the spring loaded pin on the female side
also.
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55218)
2012 RAM 5500...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
