Do you grease your tractor's PTO stub shaft?
   / Do you grease your tractor's PTO stub shaft? #1
Anonymous Poster
Epic Contributor
Do you grease your tractor\'s PTO stub shaft?
Hi,
Seems like greasing the PTO shaft of the tractor would be a good idea, unless dirt could get mixed in and cause accelerated wear.
What is the normal practice? Should I or shouldn't I?
I did grease my mid PTO shaft, but that was because I don't have a use for it and wanted to protect it from rusting...
Thanks for any advice!
   / Do you grease your tractor's PTO stub shaft? #2
Re: Do you grease your tractor\'s PTO stub shaft?
I keep it lightly greased and religiously keep the plastic cover on it. The greasing seems to let the pto coupling go on/off a little easier. /forums/images/graemlins/smile.gif
   / Do you grease your tractor's PTO stub shaft? #3
I don't `put grease because it will get dried and gummed up and covered with dirt. What I do is carry a can of WD-40 on the tractor. I always spray the pto shaft and the implement coupler before I put them together. I also use the WD-40 on the third arm and the side tilt threads any time I use them.
   / Do you grease your tractor's PTO stub shaft? #4
Gerard,
I see you are listed as being in Syracuse New York. Are you familiar with a large corporation called Carrier Air Conditioning. I worked for a couple of thier distributors in Minnesota for about ten years. And now I am one of thier dealers selling thier products.
Murph
   / Do you grease your tractor's PTO stub shaft? #5
I put an oil soaked rag in the implement end of the shaft, that helps putting it back on 6 months later. bcs
   / Do you grease your tractor's PTO stub shaft? #6
The best thing I have found is Lock Ease. It is spray graphite. The liquid carrier disolves quickly and leaves
dry graphite behind. Does not attract dirt/dust etc. Works good on the spring loaded pin on the female side
also.
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
