Do you grease your balls?
   / Do you grease your balls? #1
ElBarranco
Chama, NM
RTV
Do any of you lube the tow ball before you hook up your trailer? When I was a kid my dad always made me do that. Made sense, expect when the trailer comes off the ball is a greasy mess. After greasing up lots of clothing accidentally I decided to part ways with my dad on this issue. Now I'm wondering if the old guy knew a thing or two. Seems like some lube would help the ball socket and the ball last longer. I have a receiver hitch, not a gooseneck, in case that matters.
Any opinions?
thanks,
-robert
PS Sorry about the salacious thread title. Couldn't resist.
   / Do you grease your balls? #2
I resemble that remark, I do not grease my balls :D but it does make sense and a good idea but as mentioned very messy unless you don't mind wiping it off after each use
   / Do you grease your balls? #3
I never did, till I looked at the mowing trailer coupler one day and realized that I was looking at the ball through the top of the coupler.....
Now I do, and yes it is a mess.
   / Do you grease your balls? #4
Nope, no grease on my balls either. But I do keep my balls in the back of the truck when I am not using them so there isn't any rust on them. :)
   / Do you grease your balls? #5
No, I don't. The ball is polished chrome for a reason. The metal provides enough lube without adding to it. If the ball was old and rusty, then I might, but probably not.
   / Do you grease your balls? #6
During summer months, my gooseneck hitch ball stays worn shiney. No real need to do much. The contact between the hitch and ball is the ground contact for the trailer's electrical connection. I'd rather keep it clean.
During winter months, I usually give both surfaces a light coat of grease to minimize rust.
   / Do you grease your balls? #7
Depends on how much I have been drinking and what she looks like. I do use a Teflon based lube I picked up at Wally World. It is made just for that purpose by Reese. After I am done using the trailer I just put a ball cover on. It goes on and off easy with the lube.
Chris
   / Do you grease your balls? #8
Rather a personal question!
Oh, Trailer hitch balls.....
Spray lube
jb
   / Do you grease your balls? #9
ive been known to do it when i new i was heading out on a long trailering trip... (say 1000 miles)
my trailers are all wired up with seperate ground wire in the wireing harness so i dont rely on the ball-trailer connection for it.
   / Do you grease your balls? #10
F W J say it isnt so, using a coupled connection for a ground is not the best way to do it. Now if your saying its a backup ground, then you are correct. I have fixed more than my share of trailer problems over the years and at least 75% of then are ground related.
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2005 MACK GRANITE (A52472)
2005 MACK GRANITE...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2001 John Deere M665 (A50120)
2001 John Deere...
Case IH Farmall 75C (A52349)
Case IH Farmall...
