Do we need a warm garage....
   / Do we need a warm garage.... #11
What's in the box...it says Supervent on the out side, on the pipe it reads, Made in Canada, by Selkirk Corp. The 6" ID pipe measures a little over 8" OD, be interesting to see how hot it gets on the outside of the pipe, but the stuff sure is shinny. One thing I'm curious about when it goes together by twisting it, wonder if it will untwist by itself or does it need a screw to hold it, hummm, youtube............
Once you twist it together, it will stay, nothing else needed. You don't want to put anything into the pipe that will damage the sealed layers.
I have stainless double wall in the my pole barn and a 40 year old masonry chimney in the house. The house chimney was just inspected and it was in perfect condition. However, there is an element of luck in that whereas the stainless is kind of fool proof.
   / Do we need a warm garage.... #12
I have Selkirk, it uses a narrow clamp that catches both pieces of pipe and keeps it from unlocking. Five years old and works great.
   / Do we need a warm garage.... #13
Well that's encouraging, 30 years and still smoking, guess Canada makes good chimney pipe.
IF I had some that lasted only 10 years, it would be going back for FREE replacement!!
SR
   / Do we need a warm garage.... #14
Don't forget the clearances from all combustibles. I put bands on some joints but I don't remember if I did all of them or not. If the specs called for them then I did.
I did put 3 short sheet metal screws on each screw joint just so it wouldn't unscrew, which I would doubt it could anyway. I think that is also in the directions.
When I get my fireplace rolling with this 6 inch double walled 25' Selkirk smokestack. the stack gets pretty hot. I can't hold onto it with my hand but for a second and that is why the clearance is required.
   / Do we need a warm garage.... #15
I do need a warm garage/shop. Currently using an old kerosene heater and a propane tank with the dual burner attachment on top. What kills me is the cost of kerosene at Home Depot and the refilling of 20b propane tanks. Really want to keep my shop dryer in the winter time but it costs a fortune the way I am doing it now.
   / Do we need a warm garage.... #16
   / Do we need a warm garage.... #17
Both of the heaters you have release their combustion products directly into the shop. These combustion products have lots of water vapor in them, which is not going to make the shop dry.
To get away from this, you need to bite the bullet and install a heater which exhausts combustion products outside, an electric heater, or a heat pump.
I just added a hard-wired 240V electric heater to my garage, with a wall thermostat. The electricity is expensive, but I doubt that I will use it for more than a hundred hours per year so initial cost was a big consideration.
I could have used propane like you have, but I was afraid that the moisture would rust my tools.
   / Do we need a warm garage.... #18
I built a heated garage, attached to our house, when we lived in Alaska. We had very cheap natural gas and my house furnace was natural gas - with circulating hot water radiators. I plumbed a loop off the furnace and installed a ceiling mounted forced air hot water heater in the garage. Kept the garage at 60 degrees all winter. It was nice - kept all the ice/snow melted off all the vehicles and I could run the heat up if I was going to work out there.
   / Do we need a warm garage.... #19
From the Selkirk website on screw usage.
http://www.selkirkcorp.com/~/media/ce8e2cf643a64fcfb00566e183e3607d.ashx
Double Wall Chimney Connector Installation:
LOCATE PROPER FASTENERS
Every Double Wall Chimney Connector installation will
require at least three types of screw. Each Telescoping
Section, DCC-TS5, Adjustable Length, DCC-18A, Elbow,
DCC-45, DCC-90, Tee, DCC-T and Stove Adaptor, DCCSA
is packaged with nine screws
as follows:
Three (3) 3/4 inch long sheet metal screws, for attaching
the connector to the chimney system.
Three (3) 3/8 inch long metal screws, for fastening any
connector part to another connector part.
Three (3) 1/2 inch long thread cutting screws, for
attaching to the stove collar.
The trick is to not use 1-1/2" screws.
   / Do we need a warm garage.... #20
The double wall pipe is different, it has an air space between the s/s inner pipe and the exterior. The shiny s/s flue pipe that you see outside is filled with some sort of insulation, I wouldn't drill it personally but it's up to whoever's doing it :)..................M
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
(4) 16' Tarter Corral Panels (A50515)
(4) 16' Tarter...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
Case 721B (A47384)
Case 721B (A47384)
2017 LEEBOY 8520 ASPHALT PAVER (A51242)
2017 LEEBOY 8520...
