Do the 2538 run a bit rough?
   / Do the 2538 run a bit rough? #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
Loving my new 2538 but when moving and doing very little the tractor seems like it is hitting the governor on and off. It sounds great at first but after a while makes me wonder if they all do this? Kind of like running pretty fast across a hay lot and it gets bouncing. Not drastic by any means but never had a tractor sound quite like it.
   / Do the 2538 run a bit rough? #2
common rail your hearing variations in fuel shots as the tractor needs it per stroke. Pretty cool actually once you see the read outs on the computer.. looks like a heartbeat... this has led to better cold cranks, and even vibration and engine noise.
Certainly could be it. Sounds cool at first but then can be a bit annoying. Sounds a bit like my truck did right when I let the clutch out only not as much. Thanks for the input.
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
