Do the 2538 run a bit rough?
/ Do the 2538 run a bit rough? #1
screamin400
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
Loving my new 2538 but when moving and doing very little the tractor seems like it is hitting the governor on and off. It sounds great at first but after a while makes me wonder if they all do this? Kind of like running pretty fast across a hay lot and it gets bouncing. Not drastic by any means but never had a tractor sound quite like it.
/ Do the 2538 run a bit rough? #2
common rail your hearing variations in fuel shots as the tractor needs it per stroke. Pretty cool actually once you see the read outs on the computer.. looks like a heartbeat... this has led to better cold cranks, and even vibration and engine noise.
Certainly could be it. Sounds cool at first but then can be a bit annoying. Sounds a bit like my truck did right when I let the clutch out only not as much. Thanks for the input.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
832746 (A61166)
832746 (A61166)
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
New/Unused Landhonor 72in Rock Grapple (A61166)
New/Unused...
