DO NOT BUY TC40/45
   / DO NOT BUY TC40/45
Yeah, If i'd quit contaminating the fuel, it would be running problem free.
Appears to be fixed now
Going to get a workout this week, so we shall see.
Cross your fingers
I"m TIRED of working for free.
   / DO NOT BUY TC40/45 #112
Harold_J said:
Reading some of the opinions in this current thread it makes me wonder whether a TC would be up to this job; opinions seem to differ. What do you (or others) think? Does the TC seem more powerful than the old tractor? Would I have to stay away from the hydro and/or go with the TC55 or 2420? I think I'd like to be able to maintain at least 3+ mph mowing the bigger weeds/rye on level ground without straining the tractor. It may come down to having the local dealer letting me demo one.
Before I try to answer Harold's question, I want to congratulate Brian on his negotiations for a new tractor and also congratulate NH on attempting to do the right thing. I hope this all comes to resolution in a satisfactory manner. Too bad they can't replace all the grey hair and make up for the grief Brian has gone through after buying two new tractors.:rolleyes:
Harold, I think that a TC40 or especially the TC45 will run that 6' cutter very well. I actually think you could go larger on the TC45, but 6' seems to be a very common size because it will just cover the rear wheel width. I'm in complete agreement with Soundguy and anyone else who says these tractors should handle a 6' cutter in most every condition of weeds, grass, and brush. I believe 32-36 PTO hp is much higher than your Ford or Massey.
My old Jubilee use to really strain sometimes with a 5' cutter in high grass and weeds. I used to love to watch the governor kick in and the exhaust belch smoke as the engine tried to supply all the power the mower needed. Many times, I'd have to do a partial overlap, less than the full mower's width, to maintain the engine's rpm.
With my TC45D, when I hear the engine start to load up, the next thing I'll hear is the shearbolt going. If the 5' cutter gets in a situation where it pulls the engine down, the shearbolt can't handle the torque. Most of the times I'd hear that is if the cutter bottoms out on a high spot or I'm cutting thick heavy brush and hit something bigger. But as soon as the engine starts to bog, I know I have a chore to do at the cutter. The shearbolt just can't take it. If I had a 6' cutter and a slipclutch, that would be ideal.
So I think I can surely make a recommendation to you about the TC40/45 being a good choice for a 6' cutter. You will not have a nickel's worth of difference at the PTO between the HST and gear models. The only difference is in the pulling power of the two transmissions. For that, I'd sure recommend that demo unit from the dealer if you can swing it.
Also, a cab with AC is okay if you really have a limited use for the tractor like only using it for mowing. I just think an AC pulls too much of the engine's power. This is all just my personal opinion and since I have never operated one with a cab, it's really just a guess.
   / DO NOT BUY TC40/45 #113
I thought that was normal!?! :confused:
You mean we are actually supposed to make money??? :eek:
Dougster
   / DO NOT BUY TC40/45 #114
My cab tractor is 45/38 pto hp. and when I turn on the AC it will decrease the engine rpm's by about 100.
   / DO NOT BUY TC40/45 #115
Harold_J said:
Jinman, I'm reading this with interest because I see you own both a NHTC45D and a Ford Jubilee. I also have two tractors similar to the Jubilee, a Ford 2000 4-cyl and an MF TO-35. These are all around the same HP, weight, wheelbase.
I've recently been considering if a newer machine like a TC45 could do the same tasks and maybe a little more than the 2000 or MF35. Again all the specs on the bigger TC's seem similar to these older tractors as far as weight, HP, etc. I use a John Deere 616 rotary cutter which is a 6' medium duty type, I believe the predecesor to the M6. I really don't like running this cutter on the 2000 and usually put it on a larger 70HP White. The 2000 just doesn't seem to have enough power. I don't mow any brush, but sometimes 5-10 acres of high weeds or mature rye which stand 4-5 ft tall.
Harold J,
I have a Ford 850, and recenetly purchased a DX55 (red version of TC55), and I've also used my father's Jubilee for years. I hoped the DX55 would be a little stronger than the 850, and was surprised to find out it's a beast compared to the 850. The 45 should be relatively stronger than the 2000 in your case. As far as Hydo goes, it will depend on your needs. I like the gears on mine since I use it for plowing and heavy mowing, with minimal loader work. Both have their stengths.
   / DO NOT BUY TC40/45 #116
Jinman,
For the TC45 and TC40, the cab may not overload the system much, because, as you have pointed out, the HST will only consume about 35 HP before its internal pressure relief lifts, and the excess available HP is wasted unless one has a hog of a pto load.
My concern with a cab is the effect on fuel consumption. It is nice being able to run for several days just piddlin, without refueling. If ones business is sitting on the tractor, though, the extra 1$/hr fuel cost is probably worth it.
Chris
JUNK
The loaner, brand new TC45DA (no cab) has broken twice in 6 hours (3 jobs).
The first time, it was a plug in for the seat safety, which I managed to find and fix.
Today, with less than 50 feet to go, it just died.
couldn't even restart it.
A guy came out, got it to start (by starting it with the PTO on, which is exciting), then I had to load it and take it into the shop, so they could put the switch from my old one (which worries me to tears)
Obviously, it's not just that one that's a lemon.
Another afternoon wasted, and an additional 60 miles on the truck for zip.
Gotta mow a huge job (ok, for us) tomorrow, and taking both tractors. I have little faith it will make it thru all day.
   / DO NOT BUY TC40/45 #118
LoneCowboy said:
Oh no!!! :eek: Say it ain't so. :( Brian - Whatever you end up with that works for you is what I'm going to buy for myself... because I'll know it's been tried and rigorously tested out by the best! :)
There has got to be a happy ending coming here...
Dougster
   / DO NOT BUY TC40/45 #119
Cross your fingers
Hope none of the contamination is reaching the tractor fuel tank. At least on modern diesel trucks, there always seems to be a couple of places before the main filter that can clog and next thing you know the engine is starving. Don't know about modern tractors (I'm fanatical about clean fuel, don't want to spend hours or days tracking down and fixing a fuel problem. Going to be enough problems as it is. For my truck, I won't even refuel if the tanker is there pumping in fuel and stirring up the crud at the bottom of the underground tanks. And don't get me going on farm tank jellyfish.).
Nope, it's a stupid design on the TN
goes tank, fuel line, main pump, filter, injection pump
stupid huh? I added a filter between the tank and the fuel line, but even on my MF (1/3 of the price) there's a big screen at the filler.
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
LOT: Assorted Hand Tools (A59076)
LOT: Assorted Hand...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
LOT OF REDBAND FENCE WIRE (A58374)
LOT OF REDBAND...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
