Do most older tractors leak?
   / Do most older tractors leak? #1
sirrobinhood
Bolingbrook,IL
Kioti DK55
Hello all,
Ive been looking at some older tractors..like massey and JD. I dont think I ever saw one that didnt leak!
Anyway, should I be concerned with a slight leak..between trans and engine..I think rear seal?
Tractor sat inside on a concrete floor for a few days and had about a golf ball size oil spot on the floor.
This was on a massey 231
   / Do most older tractors leak? #2
Maybe the owner also had a Harley and just thought it was normal and never fixed it.
:confused3:
Howdy from Michigan
   / Do most older tractors leak? #3
Don't tractors and oil leaks go hand and hand. I have yet to see one other than brand new that didn't leak.
   / Do most older tractors leak? #5
That is kind of like asking if dogs bark. Some don't, some will a little and some never stop. :)
   / Do most older tractors leak? #6
If it stops leaking,....you better check the oil.
   / Do most older tractors leak? #7
And if it stops leaking, it usually stops going-soon after.......
The leaks on Old Tractors is a form of automatic controlled underbody lubrication - stops everything from rusting & seizing up.......
   / Do most older tractors leak? #8
I would say most old tractors deserve a leak here and there .
As long as it isn't running out while running it is probably ok.
Having to add a little oil is not a sign the motor will fail soon.
there are some additives for engines to soften old seals.
Compression test, clutch& pressure plate condition, hydraulic pressure would be more of a bigger worry to me than a small oil leak.
Spitting a tractor in half for a new clutch is an expensive repair.
Adding a little oil every month is not.
Just my opinion.
   / Do most older tractors leak? #9
Some of those old cast iron engine weren't mill like todays engines,some case double gasket we needed.
Oil spots..tractor just marking its spot. :)
   / Do most older tractors leak? #10
It really depends on the owner from what I've seen. They can be fixed but often enough it is cheaper to add a quart of oil.
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
Utility Trailer (A52377)
Utility Trailer...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
