do it yourself dump utility trailer...
/ do it yourself dump utility trailer... #43
Thanks!!! Fun to make to and pretty simple. Homemade about like everything else(good or bad). You might have caught the sled style/tractor/atv/everything trailer I posted about that I just finished. So I sort of have trailer on the brain. That and some 12ga 1x2 rec tubing I had in the garage. I wanted to try a little tilt/dump style so I check out the ones at HD. Hard to see the angles on the dump(angles when designing that is) but it works fine. Attached is my previous ATV trailer, wood but lasted about 11 years. The bottom went out and I had the steel for a new one. The axles and wheel are the hardest thing if you ever make one. The little HF dolly wheel won't hold up for squat. On the attached pic you can see the solid tires. Them and the bearing lasted the longest but when we hauled some firewood they basically failed. Somewhere along the line I ended up with some goat cart front wheels, no bearings, just grease the shaft. We'll see how they hold up, I just have to remember the grease. Oh and now you can see why the axle on the new trailer is red.. /forums/images/graemlins/blush.gif
/ do it yourself dump utility trailer... #44
/ do it yourself dump utility trailer... #45
RobJ, Here,s my first little dump i built.
/ do it yourself dump utility trailer... #46
/ do it yourself dump utility trailer... #47
Before paint and dumped.
/ do it yourself dump utility trailer... #49
</font><font color="blue" class="small">( RobJ, Here,s my first little dump i built. )</font>
Sweet, you skipped the light duty stuff and went with the heavy. My first little red one was designed to be pulled behind a 3-wheeler. You have the nicer wheels and a stronger axle. That'll be around for a while!
/ do it yourself dump utility trailer... #50
2009 Jeep Patriot AWD SUV (A59231)
2009 Jeep Patriot...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
208316 (A58375)
208316 (A58375)
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Autocar...
