Do I really need a tractor on 1.5 acres?
   / Do I really need a tractor on 1.5 acres? #171
I have a property with a little over 6 acres. Mostly level.
I have 3 tractors. 2 Masseys with 55 rated pto hp, one with a FEL, and their smaller sister a mf1725m with a FEL.
Overkill? I know not.
You can never have too many tractors.
I may only put on 80+ hrs all combined but I love doing big jobs ie garden of about an acre, mowing the small orchard, mowing, without having to attach and detach equipment all the time.
Snow blower in tight areas, 1725m, leveling long drive mf563, moving skids, gravel, soil, mf563 FEL.
You can never go wrong. Get more hp than you think you'll need because one day you'll need it and be happy you have it.
   / Do I really need a tractor on 1.5 acres? #172
I have been around equipment all my life. We have 8 acres all woods and I maintain the 400ft driveway, move logs, cut up trees, move brush, maintain a garden, move tri-axles loads of dirt and stone, among many other tasks with a Massey1705 that i bought new in 2016. I also mow with our tractor and it does not leave ruts. I have also used it to install driveways for other people. So I have used this tractor for a lot of things. That some might say one would need a bigger tractor. You dont. Just need the attitude that you dont mind running a tractor. IF you do go this route keep in mind the hydraulic filter is on the underside of the tractor and is exposed if you are moving brush. Brotek makes a plate to protect the filter but something to think about if you move brush.
One of the drive shafts runs very close to that filter and i have seen the shaft break and bust off the filter, ruining the entire aluminum cover it's part of. Splitting the tractor to replace it wasn't very fun, do not recommend.
   / Do I really need a tractor on 1.5 acres? #173
Hello Sea2Summit,
I'll comment to our original poster, but first, your comment here quoted caught my eye as I was considering the BX series, but now leaning to the B2601 or Deere 2025R. Would you expound a bit on the poor handling you experience. What tires do you have? Does it slip? or unstable on a slant? In my back 2 acres of woods, I have some definite hills to navigate with some wet season shallow creeks. My tractors are smaller so I was figuring the larger, 4WD would be the solution to haul out my small trailer of wood. Thank you.
In general, I wish, in hindsight, I bought bigger, but money dictated and I thought I went bigger. So that would be my advise now. I have a Ford 16HP diesel and an Ingersoll 448. They have turf tires and I keep chains on all year which is great as it helps in the woods and also prevents slipping up wet grassy slopes in the yard and also in rototilling and snow plowing. I don't need bigger for mowing or rototilling, but do for plowing and hauling. But each of these are over 30 years old and parts are hard to find for the Ford.
I would also recommend looking at the features of the tractor. eg. Treadle foot control vs two separate pedals. Or loader control on the fender or loader? I know we want to make a good decision due to the expense of these units but as many have said, you will probably be happy with whatever unit you get.
My BX handles both just fine, even with turf tires.
   / Do I really need a tractor on 1.5 acres? #174
I can't tell you what you should do but I can tell you what I did.
I have a bit over 5 acres.
I mow about 1.5 to 2 of it, the rest is wooded.
I use a 50" Cub Cadet zero turn and it is great for mowing.
But for the rest of the property I use a B2320 to maintain it.
I have a FEL, box blade and a 60" mower which I use only a few time a year and never when it's wet.
Even with turf tires it will eat the grass if it is damp.
My main use for the tractor is maintaining the driveway, clearing small trees for a trail in the woods and moving rock around (Ozarks = rocks)
Before I got the side by side I did trim mowing with a regular Cub Cadet tractor then the rest of the yard with the Kubota.
But the Kubota's weight limited when I could use it without tearing up the yard, so I replaced the Cub Cadet lawn tractor with a zero turn....which cut my mowing time in half.
I can assure you if you do buy a BX you will find many uses for it....especially if you equip it with a FEL and a rear blade of some type.
Then you can maintain your driveway and yard. And for under $2000 you can find a 48" tiller.
   / Do I really need a tractor on 1.5 acres? #175
I lived on a 1/2 lot, ranch house back in the 80's. And then . . . I ended up buying a JD 950 with a front loader. It was, shall I say, a reflection of my hope to someday own acreage. What I found was the tractor was very useful for many things around the place. Practical? Heck no. Worth it? Heck yeah. Owning a tractor is like owning a future. You get to dream, play and hope. And someday, as I found, you may actually own some acreage. Sitting happy on 122 acres deep in the Ozarks (secretly wishing I never sold that JD 950 - but happy with my NH TC40, MF 165, Ford 2000, [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] SVL95 and lots of other "toys"!)
   / Do I really need a tractor on 1.5 acres? #176
I lived on a 1/2 lot, ranch house back in the 80's. And then . . . I ended up buying a JD 950 with a front loader. It was, shall I say, a reflection of my hope to someday own acreage. What I found was the tractor was very useful for many things around the place. Practical? Heck no. Worth it? Heck yeah. Owning a tractor is like owning a future. You get to dream, play and hope. And someday, as I found, you may actually own some acreage. Sitting happy on 122 acres deep in the Ozarks (secretly wishing I never sold that JD 950 - but happy with my NH TC40, MF 165, Ford 2000, [AFFILIATE='1, nofollow=true, newwindow=true, title="Kubota"']Kubota[/AFFILIATE] SVL95 and lots of other "toys"!)
I am with you!
Its not what you need but what you want ! Just like a flat screen TV, you always seen to wish you bought bigger. I bought my first JD garden tractor, which I call a lawn mower in 1989. Then a ford 1520 in 1991 with a FEL for larger (5A) property I owned. The 1520 is still like New, always indoors and maintained, probably worth as much or more than I paid for it 30 years ago.
For a larger (10A Property in Indiana I bought a NH 4060 Boomer. ESS, MFWD, open platform,270FEL
greatest machine I ever imagined
My advise, but the biggest machine you can afford. I like New, as used equipment can be abused, even with low hours (another story). I know this forum is mostly Kubota, but any of the big three will serve you well. Much depends on the dealer you have locally. Good luck.
   / Do I really need a tractor on 1.5 acres? #177
Johng just mentioned a most important element of the whole decision - having a dealer close by for whatever brand you buy. Since you can't go wrong investing in a tractor (that removes a big part of the question), you can then just decide 'what do I want or need'! They always hold their value and bring you lots of satisfaction, happiness and fun. But when something does go wrong, having dealer close by makes it so much better.
   / Do I really need a tractor on 1.5 acres? #178
Hi everyone, forum newbie here. Recently I moved to a new property, much bigger than my last. However after seeing our neighbors down the street playing with their bx, I'm questioning if we need one (a subcompact)
We're only on 1.5 acres, it's mostly flat. There are some big dips and ruts down the rear end of the property, but nothing extrodinary. We do have a large garden just above that, and a rocky driveway that I'm considering levelling.
We do use a cub cadet xt2 46in, and this is more than adequate for mowing. However I've found it hard to turn with (seriously who in their right mind decided permanent difflock is good for a lawn mower???) And during the rainy season often times the mower will get stuck,or slide around tearing up the grass. Or most likely just bog down due to the water. Meaning mowing is a chore that will take 2+ hours
I'm planning to start a 120M x 20M garden, however this all clay soil so it's necessary to use a large tiller, of which is extremely expensive.
Preferably something to mow with during the wet, so 4wd is very much preffered.
And planning to modify the garden bed/generally move dirt ect.
I'm thinking of a sub compact but would this be the best choice? I have a Massey furgeson gc1705 with a midmount in mind, that's at a very nice price,and a loader is the cost of a new mower. Therefore I'll end up buying the loader for certain with the machine, and thankfully they are cross compatible.or should I just save my money and rent one when necessary? Hopefully with the tractor I'll sell the lawn mower, but I'm not certain yet
Did I miss where you are located? Sometimes helpful to get appropriate replies.
   / Do I really need a tractor on 1.5 acres? #179
The PTO runs close to it. Never had mine fly off. Even it did the bro-tek plate would keep it from getting damaged. PTO's just dont fly off unless the operator did not slip the joint all the way over the shaft and set it properly. Or if the mid mounted mower pto shaft was improperly sized. This seems like it would fall under operator error or dealer error.
Most every tractor that you look over that is small like scuts have some vulnerabilities. You just have to look for them and address it. The hydraulic filter placement is well known on the massey and many of us have protected and have not had any issues. I run mine in the woods every month
   / Do I really need a tractor on 1.5 acres? #180
I've put 700 hours on my subcompact with loader on 1.3 acres.
> seriously who in their right mind decided permanent diff-lock is good for a lawn mower
People with hills who couldn't get traction
Get a single tine and rip it. You need to plough sand and dolomite or gypsum DEEP through that for which you will also use the loader. Do multiple runs over time at increasing depth as the clay becomes less heavy.
> Preferably something to mow with during the wet, so 4wd is very much preferred.
700hrs @ $100/hr = 2 tractors
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2014 DRAGON 130 BBL VACUUM TRAILER (A58214)
2014 DRAGON 130...
2021 Chevrolet Tahoe SUV (A56859)
2021 Chevrolet...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
