Do I really need a tractor on 1.5 acres?
   / Do I really need a tractor on 1.5 acres? #1
shouldibuy
Member
None just looking
Hi everyone, forum newbie here. Recently I moved to a new property, much bigger than my last. However after seeing our neighbors down the street playing with their bx, I'm questioning if we need one (a subcompact)
We're only on 1.5 acres, it's mostly flat. There are some big dips and ruts down the rear end of the property, but nothing extrodinary. We do have a large garden just above that, and a rocky driveway that I'm considering levelling.
We do use a cub cadet xt2 46in, and this is more than adequate for mowing. However I've found it hard to turn with (seriously who in their right mind decided permanent difflock is good for a lawn mower???) And during the rainy season often times the mower will get stuck,or slide around tearing up the grass. Or most likely just bog down due to the water. Meaning mowing is a chore that will take 2+ hours
I'm planning to start a 120M x 20M garden, however this all clay soil so it's necessary to use a large tiller, of which is extremely expensive.
Preferably something to mow with during the wet, so 4wd is very much preffered.
And planning to modify the garden bed/generally move dirt ect.
I'm thinking of a sub compact but would this be the best choice? I have a Massey furgeson gc1705 with a midmount in mind, that's at a very nice price,and a loader is the cost of a new mower. Therefore I'll end up buying the loader for certain with the machine, and thankfully they are cross compatible.or should I just save my money and rent one when necessary? Hopefully with the tractor I'll sell the lawn mower, but I'm not certain yet
   / Do I really need a tractor on 1.5 acres? #2
Sound like you would keep that tractor busy if you do buy one... renting is throwing money away especially if its more than one shot deal, buy it and you will put it to work essentially saving money in rent and when you sell it you will get most of your money back and that will be much more cost effective the accumulation of rent fee, and once you have one you will find other use for it as you go along.
   / Do I really need a tractor on 1.5 acres? #3
Well you're concerned about damaging your lawn when it's wet with a ~600lb mower....you don't want to see what a ~1,500lb tractor is gonna do to it when it's moist!
I got my BX when I had about 1.6 acres with less than an acre usable. I absolutely used the crap out of it landscaping from bulldozed woods to a yard with several raised beds over the course of two years. That being said, the BX does not handle rough terrain or inclines well. So depending on your yard, you may need to prep it with another machine if you intened to work that area with big dips and ruts.
If you have the funds, I think every man should own a tractor.
   / Do I really need a tractor on 1.5 acres? #4
I don't think there is an accurate ratio of tractor size to home acreage. I make no apologies that I have a 40hp tractor with FEL on only 6 acres. My property maintenance and projects dictate a larger machine.
Unless you want to contract out, a gravel driveway alone would justify a scut and FEL (Imho). A BX (or similar machine) with a mid mount mower is a capable mowing machine that will likely do less turf damage than a poor traction lawn mower spinning its wheels. As an example, I got half way across my water soaked field in a golf cart before burying it. It stripped the turf down to bare mud while spinning (ughh). I drug it out of the field with my L4060 just leaving tire lug impressions in the turf... They're probably gone now.
I have never heard of a lawn mower with the rears permanently locked. That thing must be a pain to operate!
As for the mower comment, I have nearly snapped the axle twice, both times running into stuff since it tends to "jump" ie has delay and shoots forward, which with the back wheels forcing it straight is. Well let's just say many curse words have been had.
For the wet ground that was my thought, sure the tractors far heavier, but with the wheels spinning and digging ground/stripping grass I still have deep ruts and bare ground. Atleast with a tractor I should avoid slipping, which does get scary when the wheels decide to gain traction and you find yourself hurtling towards whatever you didn't want to goto.
I was actually looking at some Chinese tractors the other day, but the min ratings of 30-40 HP and size turned me off them lol, but I definitely understand why people would want a machine that size
Yeah my primary concern is just the sheer weight, but I figure the tractor will create ruts (maybe) but atleast leave the ground okay, however the mower is worse than a skid steer half the time. Since it's spinning so much all it does is dig in and tear up the grass. I'll definitely look into it however
Yeah,I definitely think I'll be using it like no tomorrow, especially with now it taking potentially 3 weekends to move much of anything (waiting for the grass to dry so it's safe, then it dries to quickly and nothing short of dynamite will move that dirt) having mechanical force will be a welcome difference
And what man wouldn't love a 72inch deck instead of a 46 inch one.
As for inclines and ruts, mostly the worst area is just dips, which to my knowledge I haven't bottomed out on. But I have come close and shaved dirt once or twice on the mower when going slightly too fast. But as long as the tractor deck isn't lower, or the frame is longer I should be okay
Exactly what I was thinking, we did rent a zero turn for Abit to try, but discovered when it's wet. Well let's just say I learnt that "drifting" a lawnmower is possible. The main reasoning is once I rent a tiller 5-10x a year, plus digger to level and move dirt atleast 1-2times I'm quickly coming up to the price of a semi decent used tractor. Let alone our mower just not being usable for 1/4 of the year. The biggest expense will be adding a loaded, but the gc05 model and 23/25 model all have cross compatible loaders and mowers, so worst case it's still somewhat cheaper. (However they want 30'000 for a new one, and even I can't justify that ontop of house repayments)
I have a neighbor who has a bx that has maybe 1/4 acre. As far as mowing his small lawn, it looks just as good as mine with my expensive zero turn. Plus, I have a wheel borrow. He doesn't. Lol
Haha yeah, when we tried out a rented zero turn, I was shocked at how good it cut. And even though it was 60', I really did appreciate the larger deck size. Granted when it rained it was a different story, and in the tropics it rains ALOT lol
   / Do I really need a tractor on 1.5 acres? #10
It's not a lawn mower, but I'm not sure that there is anything on the market to compare with the small old style Farmall tractor for doing large gardens. Especially in clay soil.
Luckily there are lots of used ones on the market and they are so simple they last forever.
If you go that route, get every attachment you can find.
rScotty
   / Do I really need a tractor on 1.5 acres? #12
I live on 3 acres but mow about the same amount as you. If all you will use it for I’d say maybe. If you will use it for other things, for sure yes. For example I use mine for handling fire wood, gravel, dirt, landscaping and other tasks. I had a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] BX for 10 years and now a John Deere 2025r. I look at it as a long term investment you won’t regret.
   / Do I really need a tractor on 1.5 acres? #13
I had a 32 hp compact while I lived in Corrupticut. We had 1.2 acres and I used it almost every day.
   / Do I really need a tractor on 1.5 acres? #14
I bought a Kabota BX 25 tractor loader backhoe for my three-quarter acre cottage property. Used it a lot, including preparation of my garage pad. Now we have another property 500 m away that’s 25 acres. Never looked back!
   / Do I really need a tractor on 1.5 acres? #15
OP, sounds like you have enough uses to justify a sub-compact tractor purchase. And, you’re already heading in the right direction, the MF GC1705 is a fantastic tractor. However, I’d go with the GC1723. ;)
Mike
   / Do I really need a tractor on 1.5 acres? #17
Looking at it by tasks is good. Mowing, rototilling, snow removal, lifting stuff on/off trucks, firewood, field mowing. The other way to look at it is it is a platform. Think of the tractor as the powerhead to a Stihil Kombi unit. Buy the head once and add an attachment when/if you need it vs an engine for each.
I wish I had thought of that before I started out as I had some dumb purchases had I just bought the tractor up-front.
   / Do I really need a tractor on 1.5 acres? #18
Shouldibuy
YES you have convinced this group beyond a doubt that you can justify a small tractor and front end loader. We like helping you spend money wisely.
Always remember - As you get older your WANTS can be reclassified as NEEDS.
Useful toys (work equipment and tools) also make great gifts to your spouse. My lovely wife has a compact tractor with front end loader and a really nice 60 inch ZTR. IIRC one was a Birthday gift and one for Valentines day. She occasionally reminds me that she has never used either one but since I am her best behaved child I get away with it along with a few roses and dinner.
Enjoy your new work tool.
   / Do I really need a tractor on 1.5 acres? #19
I'm on 2.5ac of pine running the Kioti CX2510. I absolutely love the thing and everything it's helped me with! I have zero regrets with the purchase.
   / Do I really need a tractor on 1.5 acres? #20
Make a list of things you will do once every five years, once a year and every couple of months. Look at cost of renting or hiring out seldom performed tasks vs buying too much machine or too many attachments.
If it is a toy or hobby, do not worry about it and get what you think you want. Need has little to do with it.
As to your uses. Hard to fathom rototilling 5-10 times a year...is that a need to want?
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
CFG Industrail MX15RX (A53317)
CFG Industrail...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
404 (A52706)
404 (A52706)
