Do I need to bleed hydraulic lines?
   / Do I need to bleed hydraulic lines? #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
I want to run two hydraulic hoses from the remote valves on back of my tractor up to the grapple attachment on the front loader. Do I need to some how bleed the air out or will it get forced out when I cycle it?
   / Do I need to bleed hydraulic lines? #2
Not necessary to "bleed" the lines. 2000# is suficient to push any air out after a couple of cycles.:rolleyes:
Besides that, that is a lot of pressure and not safe to be loosening the lines with pressure on them (like a hyd brake line). Do not do it. It will self bleed after a few cycles of the cylinders.
Mike
Mike,
Thanks for the quick answer! I will give it a try hopefully this weekend.
   / Do I need to bleed hydraulic lines? #4
Don't forget to check your hydraulic oil level afterward. The oil in the new lines and cylinder(s) have to come from somewhere. ;)
CCWKen,
Thanks for the reminder. It will probabily take me 20 minutes to find the fill plug.
   / Do I need to bleed hydraulic lines? #6
Glad to be of some small help. Do let us know how things go for you.
Mike
   / Do I need to bleed hydraulic lines? #7
Gene, it may take several cycles to get all the air out. If so, it could be spongy for awhile, but I used 1/4" hoses about 15' long and don't recall ever having any air bleed problems. You are gonna show us some pictures, aren't you?:)
Jinman,
You bet I'm going to post pictures.
The plan is to run the lines and try it out today and tomorow.
The good news is that among other modifications I got the hydraulic lines ran and briefly tested it out in the barn. After cycling it a few times it worked great! It was to muddy out to take it out to the woods to really put it though the paces. The next time we get a heavy frost I'll have to take a run with the tractor out to try it on some unsuspecting trees. The last 3 days I have spent so much time out in the barn working on the tractor that my wife thinks I have a girl friend.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2020 Toro 6000 Series 60in Zero Turn Mower (A50322)
2020 Toro 6000...
2016 Ram 5500 Chassis Truck, VIN # 3C7WRNAL2GG280521 (A50323)
2016 Ram 5500...
John Deere 12' Grain Drill (A50515)
John Deere 12'...
Excavator Bucket (A50514)
Excavator Bucket...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
