Do I need to bleed hydraulic lines?
   / Do I need to bleed hydraulic lines? #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
I want to run two hydraulic hoses from the remote valves on back of my tractor up to the grapple attachment on the front loader. Do I need to some how bleed the air out or will it get forced out when I cycle it?
   / Do I need to bleed hydraulic lines? #2
Not necessary to "bleed" the lines. 2000# is suficient to push any air out after a couple of cycles.:rolleyes:
Besides that, that is a lot of pressure and not safe to be loosening the lines with pressure on them (like a hyd brake line). Do not do it. It will self bleed after a few cycles of the cylinders.
Mike
Mike,
Thanks for the quick answer! I will give it a try hopefully this weekend.
   / Do I need to bleed hydraulic lines? #4
Don't forget to check your hydraulic oil level afterward. The oil in the new lines and cylinder(s) have to come from somewhere. ;)
CCWKen,
Thanks for the reminder. It will probabily take me 20 minutes to find the fill plug.
   / Do I need to bleed hydraulic lines? #6
Glad to be of some small help. Do let us know how things go for you.
Mike
   / Do I need to bleed hydraulic lines? #7
Gene, it may take several cycles to get all the air out. If so, it could be spongy for awhile, but I used 1/4" hoses about 15' long and don't recall ever having any air bleed problems. You are gonna show us some pictures, aren't you?:)
Jinman,
You bet I'm going to post pictures.
The plan is to run the lines and try it out today and tomorow.
The good news is that among other modifications I got the hydraulic lines ran and briefly tested it out in the barn. After cycling it a few times it worked great! It was to muddy out to take it out to the woods to really put it though the paces. The next time we get a heavy frost I'll have to take a run with the tractor out to try it on some unsuspecting trees. The last 3 days I have spent so much time out in the barn working on the tractor that my wife thinks I have a girl friend.
Club Car (A50324)
Club Car (A50324)
(9) SHANK ALL PURPOSE PLOW (A51243)
(9) SHANK ALL...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
5' X 20' 3/8" THICK STEEL PLATE (2) PIECES (A51244)
5' X 20' 3/8"...
