Do I need a voltage regulator?
/ Do I need a voltage regulator? #1
Jmalone
I have a 2000 Ford 64 Model I think..12 volt..running a Chevy Alt. This thing is charging so much the battery is super hot..its actually boiling over. I thought these alternators had built in regulators? Do i need to install a regulator? Also, My voltage guage doesnt work....It has a new guage in it, but it isn't wired up....What wires do I need to run and where?
/ Do I need a voltage regulator? #2
If its a modern 10SI or 12SI GM alternator it should not need one. I would take both the battery and the alternator into the nearest parts store and have them checked out. My guess is the alternator is bad. A new rebuilt 10SI should be about $60.
As for the wiring if its a single wire alternator it should go to the positive post on the battery. Same thing with the voltage gauge. The gauge will also need a ground.
This brings up 2 more thoughts. Is the battery a 12 volt or 6 volt? It should be 12 Volt. Also, the tractor should be wired negative ground if running a alternator. I know my Ford 861 was positive ground but I had to switch it all around to negative ground when I did a 12 volt conversion from 6 volt with a 10SI alternator.
Chris
Yeah, it has a 12 volt battery and a one wire GM alt. But after about 1-2 hours of use depending on the RPMS, the battery smells of sulfur, and I can literally see it leaking over, and hear it boiling...of course pulling the neg just makes the tractor die after about 2-3 minutes..
also, I can just hook up the guage from running one wire to the POS and one to the NEg on the 12V battery?
/ Do I need a voltage regulator? #5
If you are boiling the battery that quick and it dies in 1-2 minutes after boiling over I think your battery is bad. A tractor should run for hours if not days on a battery even with no alternator. Older Tractors unlike cars really only use the battery to start the machine and keep the ignition going. Well I guess that is true for older cars also. But like I said I would take them both into the parts store to have them checked. I would hate for you to buy a new battery and ruining it also.
As for the gauge, a wire to the positive and one to ground should take care of it. I would ground it to the chassis of the tractor.
Chris
/ Do I need a voltage regulator? #6
for the voltmeter, connect the + side of the meter to the run terminal of the ignition switch, and a good ground on the - side of the meter, that way the meter isnt drawing current no matter how slight all the time. If you run a direct connection to the battery unfused, its always a potential to rub through the wire eventually creating a short and causing a fire.
/ Do I need a voltage regulator? #7
If you find your battery is bad, don't think that is necessarily your only problem. A faulty alternator (bad internal regulator) could ruin a battery. You don't want to mess up another battery. Put a handheld voltmeter on your battery. These can be had from Harbor Freight for $3. If voltage is much above 14, you may have a bad voltage regulator. I forget the exact number of normal voltage...13.7, 14.2? Certainly 15 volts or above is a problem.
-Jay
/ Do I need a voltage regulator? #8
pulling negative? man.. tht's harsh.. pulling the gound of fthe battery.. now the alt is stuck with voltae spikes due to such low loads that intermittantly open (open)
fastest way I know to kill an alt is to install it reverse polarity. next fastest way I know to kil lthem is to remove a bat cable with them running.
take the alt and battery to the store for a check. if the alt is bad, get a CHEAPER 3 wire 10 si. wire the #2 spade to the charge stud, wire the #1 spade to the lil dash lapmp which comes on when the key is turned on. wire charge stud to hot side of solenoid.
if you have a volt gauge, wire one side to chassie, and the other side to the key switch where the primary wire to the coil is hooked. ie.. neg on gauge to chassie.. + to switched side of key.
soundguy
/ Do I need a voltage regulator? #9
14.4 is a common charge rate for a gm alt.. but you can get 14.7 too. I'd call anything above 14.75 at the battery excessive.
soundguy
got it fixed..took it to a rebuilder. He repaired the bad regulator in 30 min. charged me 25 bucks...sweet deal!:thumbsup::laughing::D:thumbsup::laughing::D
/ Do I need a voltage regulator? #11
did they set it back up as 1 wire or 3 wire. Even if 1 wire.. many will work as 3 wire.. which is what I'd set it up as.
Oh.. and don't pull any bat cables off to test it.. hard on the alt. :)
soundguy
/ Do I need a voltage regulator? #12
Glad you got if fixed. I would plan on a new battery in the near future. You may get lucky but I would think that one is shot after what its been through.
Chris
/ Do I need a voltage regulator? #13
yep.. I'd check the sells with a specific gravity gauge.. if it's not good replace it.. or it can kill the new alt
2023 RIPPA R360 EXCAVATOR (A62129)
2023 RIPPA R360...
2023 Case IH 110C Tractor W/ Case IH L630 Loader (A64047)
2023 Case IH 110C...
Sakai SV505 (A60462)
(APPROX.16), 40"X118" INSULATED PANELS (A62131)
(APPROX.16)...
GMC 2500HD 4wd Service Truck (A63118)
GMC 2500HD 4wd...
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
