Do i have a Jd 755 or JD 855 engine??
   / Do i have a Jd 755 or JD 855 engine?? #1
Wolfman37
Wisconsin
JD 755
The hood of my tractor say 755.
My fuel shut-off solenoid is located (and is the same as) where the 855 should be located.
How do I determine which engine I really have?
Are there pictures on the net where I can see a full picture of each engine on either side?
Thanks
   / Do i have a Jd 755 or JD 855 engine?? #2
Easy ways to compare motors in the 755 (3TNA72UK) would be to measure oil capacity (2.7L (2.86 qts) and compression (22.3:1) or bore x stroke 72 x 72 mm. vs. 855's 3TN75RJ oil capacity (3.6L (3.8 qts) and compression (17.8:1) or bore x stroke (75 x 75 mm).
The oil capacity ought to be your first and easiest test. Compression next.
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
71053 (A49346)
71053 (A49346)
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
