Do i have a Jd 755 or JD 855 engine??
   / Do i have a Jd 755 or JD 855 engine?? #1
Wolfman37
Wisconsin
JD 755
The hood of my tractor say 755.
My fuel shut-off solenoid is located (and is the same as) where the 855 should be located.
How do I determine which engine I really have?
Are there pictures on the net where I can see a full picture of each engine on either side?
Thanks
   / Do i have a Jd 755 or JD 855 engine?? #2
Easy ways to compare motors in the 755 (3TNA72UK) would be to measure oil capacity (2.7L (2.86 qts) and compression (22.3:1) or bore x stroke 72 x 72 mm. vs. 855's 3TN75RJ oil capacity (3.6L (3.8 qts) and compression (17.8:1) or bore x stroke (75 x 75 mm).
The oil capacity ought to be your first and easiest test. Compression next.
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
