Do i have a Jd 755 or JD 855 engine??
   / Do i have a Jd 755 or JD 855 engine?? #1
Wolfman37
Wisconsin
JD 755
The hood of my tractor say 755.
My fuel shut-off solenoid is located (and is the same as) where the 855 should be located.
How do I determine which engine I really have?
Are there pictures on the net where I can see a full picture of each engine on either side?
   / Do i have a Jd 755 or JD 855 engine?? #2
Easy ways to compare motors in the 755 (3TNA72UK) would be to measure oil capacity (2.7L (2.86 qts) and compression (22.3:1) or bore x stroke 72 x 72 mm. vs. 855's 3TN75RJ oil capacity (3.6L (3.8 qts) and compression (17.8:1) or bore x stroke (75 x 75 mm).
The oil capacity ought to be your first and easiest test. Compression next.
2008 FREIGHTLINER M2 FLATBED (A50854)
2008 FREIGHTLINER...
1240 (A50490)
1240 (A50490)
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
