DK55 wont go forward
/ DK55 wont go forward #1
double hunter
Ford 1715
Me and a buddy are looking at a Dk55,,runs good, wont go forward,,will go in reverse,,any ideas what it might be or what to check,,thanks
/ DK55 wont go forward #5
I'm not sure how they are setup but I believe that it is a synchronized shuttle,
not a power shuttle it may not have clutch packs. Just gears and a single disk clutch.
/ DK55 wont go forward #6
The DK55 is a 3+4 gear transmission with synchronizers in the 4 speed and a single disk dry clutch. When you say it wont go forward, is there anyway to confirm if the transmission shift lever is all of the way forward? One of you climb under the tractor and watch the linkage to see if it is moving. Another test is try to push the direction lever forward without depressing the clutch. Push hard and listen for gear noise.
/ DK55 wont go forward #7
Didn't think the DK 55 was ever offered in HST? just shuttle
I think you're correct after additional googling. Prior to my post I searched just to make sure, but looks like I read/saw a link for a 40 with hst, not a 55.
It is a shuttle shift,,we're gona go back and look at it again,,it was raining and cold the other day when we were looking,,if the clutch was bad would it move in reverse,,Im thinking linkage or something broke in the tranny
/ DK55 wont go forward #9
The clutch only turns one direct. It does not care if the transmission is in forward or reverse.
/ DK55 wont go forward #10
Bent Shuttle Fork or bad Shuttle Synchronizer Hub would be a place to start. Does not sound like a clutch issue from the brief description in your post.
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
(2) UNUSED 10-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 10-16.5...
