DK55 hydralic side link
/ DK55 hydralic side link #1
curly
Platinum Member
Union, SC
2013 Kioti CK35 HST
Anybody got a hydralic sidelink on a DK55 that can give me info on what to get?
/ DK55 hydralic side link #3
If your dealer carries Gearmore products, have him get you part number 1-L3X4-15KI.
Gearmore seams to hold up the best as far as seals go. The only thing is that this cylinder is pricey. ($310+-) It is a 3 inch bore cylinder with a 4 inch stroke and the total length of it is 15 inches from pin to pin. The nice thing about the Kioti made Gearmore cylinders is that they are pretty much just a pin on application for easy insatalation. All that is needed are hoses and couplers.
tractorhill said:
wehave one in stock
Bill,
How much is it with the hoses on it, ready to plug into one of the remotes in back?
Thanks
/ DK55 hydralic side link #6
curly said:
Anybody got a hydraulic sidelink on a DK55 that can give me info on what to get?
We will make you a custom fit side-link, 6" stroke with a double piloted check-valve for $250. Don't settle for a may work off the shelf cylinder, if you can have just what you want. The double piloted valve will set us apart from the other venders.
Mark Carter
Mark Carter
OK, I'll take one :D I need it to fit my Kioti DK55. What info do I need to give you. I want the hoses on it and ready to plug in, can you do that?
You have a PM.
/ DK55 hydralic side link #8
Mark Carter
Do you have any pictures of one and what brand are they? It would be nice to see what they look like.
/ DK55 hydralic side link #9
We fabricate the ends and weld them on here in TN. Our side-links vary to the customers application, size & category of tractor but all of them have the check-valves on them. This is a sample of one of our side-links.
LMC Box Blade (A64126)
213324 (A64279)
213324 (A64279)
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
