DK55 Help
/ DK55 Help #1
ocaj11
Northeast Texas
John Deere 5325 4wd, Kubota B7500 HST
Guys,
I bought a DK55 last year but never received the owners manual. I plan to get one sent to me soon, but I need some info. What type of hydraulic fluid does the DK55 use? Does it really matter if the wrong hydraulic fluid is used? Without knowing much about hydraulic fluid, I would think any hydraulic fluid sold at Tractor Supply would work....I'm sure I am wrong about that.
I've had a few issues with the tractor. Last week, I developed my second hydraulic leak and need to add some fluid.
Thanks for the help.
/ DK55 Help #2
I just run a heavy duty tractor hydraulic/transmission fluid in my DK 35.
/ DK55 Help
Thanks Vince. We have a JD Backhoe and we have plenty of hydraulic fluid that is JD 303 rated. I will use that. The 50 hour service is coming up in a couple of weeks, so the dealer will be adding new fluid anyway.
Have a great day!!!
/ DK55 Help #4
</font><font color="blue" class="small">( Thanks Vince. We have a JD Backhoe and we have plenty of hydraulic fluid that is JD 303 rated. I will use that. The 50 hour service is coming up in a couple of weeks, so the dealer will be adding new fluid anyway.)</font>
That should be fine. Any quality hydraulic fluid is probably okay. Warren AW68 is another good one. TSC universal is also a good bet. I hope you're going to have the dealer fix the leaks. Usually turns out a connection is cross threaded, or an oring got squished by tightening a little too much. John
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
(4) Firestone 21.5L-16.1 Turf Tires (A64912)
(4) Firestone...
2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
2023 Maybridge M79...
WhisperWatt 125KW Gen Set DB-1381J2 (A64911)
WhisperWatt 125KW...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2007 Ford F-150 King Ranch (A64911)
2007 Ford F-150...
