DK5310SE Loader hydraulic hose routing
   / DK5310SE Loader hydraulic hose routing #1
skipples
Somis, CA
Kioti CK35 HST, Kioti DK5310SE HST
Mine appears to be wrong. Up = loader down; down= loader up. Something seems to be wrong with the hose connections. Been that way since delivery new last year. Different from my older ck35.
   / DK5310SE Loader hydraulic hose routing #2
Just swap the quick disconnects below tractor at valve. They should be color coded.
   / DK5310SE Loader hydraulic hose routing #3
Can’t believe that you’ve put up with this for a year….without talking to your dealer!?
However, in case I’m not understanding you properly. Pull the lever, to raise arms up. Push the lever, to lower arms.
Push lever to the right, bucket dumps. Pull lever left, bucket curls up…
   / DK5310SE Loader hydraulic hose routing #4
It doesn't even need to be taken to the dealer. Just disconnect the 2 hoses for the lift function, swap them and it's fixed.
   / DK5310SE Loader hydraulic hose routing #5
I agree. But at “the first service” would be a perfect time to have the dealership get oil on their sleeves…
   / DK5310SE Loader hydraulic hose routing #6
Did you make sure the hoses are in the right spots at the Loader Hose Disconnect? Should be color coded.
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
CATERPILLAR HYD HAMMER (A52707)
CATERPILLAR HYD...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
1990 PETERBILT 320 HYDROVAC (A55745)
1990 PETERBILT 320...
CATERPILLAR H120S HYD HAMMER (A52707)
CATERPILLAR H120S...
