DK5310SE Loader hydraulic hose routing
   / DK5310SE Loader hydraulic hose routing #1
skipples
Bronze Member
Somis, CA
Kioti CK35 HST, Kioti DK5310SE HST
Mine appears to be wrong. Up = loader down; down= loader up. Something seems to be wrong with the hose connections. Been that way since delivery new last year. Different from my older ck35.
   / DK5310SE Loader hydraulic hose routing #2
Just swap the quick disconnects below tractor at valve. They should be color coded.
   / DK5310SE Loader hydraulic hose routing #3
Can’t believe that you’ve put up with this for a year….without talking to your dealer!?
However, in case I’m not understanding you properly. Pull the lever, to raise arms up. Push the lever, to lower arms.
Push lever to the right, bucket dumps. Pull lever left, bucket curls up…
   / DK5310SE Loader hydraulic hose routing #4
It doesn't even need to be taken to the dealer. Just disconnect the 2 hoses for the lift function, swap them and it's fixed.
   / DK5310SE Loader hydraulic hose routing #5
I agree. But at “the first service” would be a perfect time to have the dealership get oil on their sleeves…
   / DK5310SE Loader hydraulic hose routing #6
Did you make sure the hoses are in the right spots at the Loader Hose Disconnect? Should be color coded.
2019 Ford Fusion Sedan (A48082)
2019 Ford Fusion...
2002 Blue Bird F131612 Bus (A48081)
2002 Blue Bird...
Golf Cart (A48082)
Golf Cart (A48082)
Perfecta Harrow (A49251)
Perfecta Harrow...
78in Large Capacity Bucket (A49251)
78in Large...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A46684)
2018 Ford F-150...
