Dk50se r4 rear tire pressure
   / Dk50se r4 rear tire pressure #1
blucoondawg
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
I have a dk50se with the Titan r4 tires, my rears don't seem to have a max or recommended tire pressure listed. Anyone with the dk40,45,50se series tractor know the where the rears should be for pressure
   / Dk50se r4 rear tire pressure #2
Max tire pressure is usually too hard. Ideal pressure to me is where I get slight sidewalk flex and a good full contact patch under load. That condition will give you the better traction and ride, and be easier on bearings than max pressure. Exact target pressure will probably take a little experimentation with whatever implements and jobs you do. My rears have stayed where I set them for a few years, but my fronts I’ll adjust upwards near max for loader work and then air them down again when the loader comes off.
   / Dk50se r4 rear tire pressure #3
This might help 933DF5FA-3CBE-42E6-A303-A58421E21381.jpeg R4 would be industrial
   / Dk50se r4 rear tire pressure #5
Just a note per that page those are the max not to exceed pressures,
your needed operating pressure could be considerably less.
   / Dk50se r4 rear tire pressure #6
I settled on 14 psi in my DK5010's 14.9 x 24 R4s to get a good contact patch. They are loaded with plumbing antifreeze and I normally have my 1300lb counterweight attached.
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Fuel Tank (A51573)
Fuel Tank (A51573)
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
