Dk50se r4 rear tire pressure
   / Dk50se r4 rear tire pressure #1
blucoondawg
Gold Member
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
I have a dk50se with the Titan r4 tires, my rears don't seem to have a max or recommended tire pressure listed. Anyone with the dk40,45,50se series tractor know the where the rears should be for pressure
   / Dk50se r4 rear tire pressure #2
Max tire pressure is usually too hard. Ideal pressure to me is where I get slight sidewalk flex and a good full contact patch under load. That condition will give you the better traction and ride, and be easier on bearings than max pressure. Exact target pressure will probably take a little experimentation with whatever implements and jobs you do. My rears have stayed where I set them for a few years, but my fronts I’ll adjust upwards near max for loader work and then air them down again when the loader comes off.
   / Dk50se r4 rear tire pressure #3
This might help 933DF5FA-3CBE-42E6-A303-A58421E21381.jpeg R4 would be industrial
   / Dk50se r4 rear tire pressure #5
Just a note per that page those are the max not to exceed pressures,
your needed operating pressure could be considerably less.
   / Dk50se r4 rear tire pressure #6
I settled on 14 psi in my DK5010's 14.9 x 24 R4s to get a good contact patch. They are loaded with plumbing antifreeze and I normally have my 1300lb counterweight attached.
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
2012 DODGE Grand Caravan (A56859)
2012 DODGE Grand...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
