Dk45se pto problem
/ Dk45se pto problem #1
Dakotabluelightning
Shelby nc
Dk45se
My dk45se pto won't come on. Switch has power but the dash light won't come on and pto won't come on. Need help.
I ve checked the switch and it seems to be working. I have power out of the switch on a yellow with orange stripe wire. Fuse is good. Does the switch activate a solenoid? Where might that solenoid be? I can only locate 2 on the right side under and in front of the FEL control. And as well as I can see, neither has a yellow with orange stripped wire going to them. Is there another one somewhere?? Help!!
/ Dk45se pto problem #3
Usually the switch activates a relay. Then the relay energizes the solenoid.
/ Dk45se pto problem #5
I don't know. I'm not familiar with your tractor. Some tractors have it located on the side of the transmission housing, usually on the right but then again, it may vary.
/ Dk45se pto problem #6
Ok, I found the workshop manual for your tractor. Can be found here: demss.co.kr - /dossfile/manualn/WMFILE/DK35SE-45SE/
I didn't realize your tractor had the electric over hydraulic 4WD actuation.
So you'll have what they call: Modulator valve. This is basically an hydraulic block with two solenoids and a bunch of sequence/relief valves. One solenoid is for the PTO and another is for the 4WD. I'm assuming this is what you've found.
/ Dk45se pto problem #9
ptsg, thank you sir, for the shop manual. Made my day! I could not fine one for my 2013 DK45SE
/ Dk45se pto problem #10
There’s a dual relay/ solenoid under the dash cover. I had to replace mine for similar intermittent issues.
look thru this post. I posted schematics and phot
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
19020SFL (A64553)
19020SFL (A64553)
2015 DRAGON PRODUCTS CRUDE TRAILER (A67714)
2015 DRAGON...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
KAWASAKI 95ZIII Radiator (A68134)
KAWASAKI 95ZIII...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
