DK45SE/Landpride 2572
/ DK45SE/Landpride 2572 #2
Yes, it should handle a 6 footer with ease. Hopefully you are getting it a lot cheaper than the one listed on Tractor House.
/ DK45SE/Landpride 2572 #3
I run a 6' rfm mower behind my 45, and I see no reason why it couldn't handle 7'. I know it isn't an apples to apples comparison with mine being a woods and all, but not that much different. Just so you know, I cut weeds (2-3 foot high stuff) with my 6' RFM too, just takes a couple of passes to chew it up fine.
Nah, the one I'm looking at is pretty firm at $850. I was hoping, as always, to get it just a little cheaper and I probably would have went ahead and done it. I'm leaning towards getting it anyway because it looks to be in good condition.
/ DK45SE/Landpride 2572 #5
We will run 7' Kioti Finish Mowers behind everything from CK35 up depending on the customers yard.
6 ft HD rotary is good for a 45 or a 7' medium duty cutter, again depending on what you are cutting and where you are using it.
BTI
I picked up the cutter today and that thing is heavy. I used the FEL to get it off the trailer and was going to just drive it to the back of the house to set it down. Well, I can tell right now from this and also from moving some dirt piles last week that getting the rear tires filled is almost a necessity unless I am going to keep some other kind of weight on the rear. Today, while moving the cutter, the tractor got only slightly on a sideways lean and the left rear wheel started picking up. This had also happened while moving the dirt last week but I was unsure what the dirt weighed, though I was thinking it didn't look like much. I understand that I wasn't on perfectly level ground, but I sure didn't think that it was enough today that it would have brought the tire up. From what I've read, the cutter weighs in the neighborhood of 1000# or maybe a little more and I only had it about a foot off the ground. The bucket itself was probably about five feet up. I ended setting it down and using the 3pt to move it.
/ DK45SE/Landpride 2572 #7
I see you already have picked it up. That said, run a 6ft. Landpride and a 7ft. Kioti RFM on my 45SE and it's fine. Just cut 7 acres with both last week.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2022 EZ-GO ELITE...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
