DK45HST Rear remotes, size and fitting
   / DK45HST Rear remotes, size and fitting #1
airlynch
Meatloaf Mtn WI
Kioti DK45SE HST
Hello first post. Bought a 2013 DK45 HST this summer (26 hrs so far so good). I just purchased and put together a 3pt log splitter and need to buy hoses and fittings. I think the rear remotes are 1/2" but not sure what other spec to reference for the male quick connections. A few questions I am hoping you can help me with:
-Are the rear remotes 1/2"?
-What male quick connect fittings do I need?
-What is the psi and gpm at rear remote?
-Of the rear remotes which is supply and which is return? (note: I added a second set of rear remotes on purchase but not sure if the set runs vertical or horizontal, think its vertical but want to verify)
Thanks for your help
   / DK45HST Rear remotes, size and fitting #2
Pioneer 1/2 in. Standard ISO Tip, 3/4 In., 16 ORB, Fits All Current Models, Ball Style, from the TSC web site. You have two sizes on these fitting, threads size and tip size. I believe on my DK 45 SE The loader tips are 1/2 and the rear remotes tips are 3/4in. The way mine are set up pulling back on the hyd control operates/pressurizes the bottom remote( usually extending the cylinder) and the top remote is pressurized with the foward movment of the control( lowering or collapsing the cyl). Usually the tip is one size larger than the hose for the same flow.
Thanks. I will let you know how it goes. Much appreciated.
Dan
   / DK45HST Rear remotes, size and fitting #4
Total Pump Flow 16.8 gpm (63.9 L/min)
   / DK45HST Rear remotes, size and fitting #5
1/2 inch "AG" also known as Pioneer, also known as ISO 5675. ISO 5675 Agricultural Hydraulic Quick Couplers
each set is vertical, Up and Down. neither one is source or tank, they are both functions depending on which way you push or pull the control valve lever.
Total flow is 10GPM at the remotes.. The other 6 is for the power steering which is totally hydraulic (no mechanical connection from the steering wheel to the front wheels)
Thanks everyone for the help. I was able to figure it out after some trial and error. I am dead tired but was able to put up a lot of wood today. Thanks again for all the help and that is not only on this issue, but I relied on your posts as a vital part in my decision on buying the Kioti DK45se HST. I am now 30 hours in and it has exceeded my expectations. The work that you can do with these is truly impressive. Here are some pic's:
Easy Does It
-Dan
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
CASE 610 Sprayer System 2000 Gallons (A55315)
CASE 610 Sprayer...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2020 CAT 308 (A53317)
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
